[Mapserver-users] mrSID
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 22 09:14:31 EDT 2003
Frank Warmerdam wrote:
> Bruno Luis wrote:
>> I was wondering... does MapServer support mrSID images?
> Bruno,
> The GDAL library (you would need a CVS snapshot) does not support the MrSID
> format ... if you have a licensed copy of the MrSID library when you
> build it.
> When GDAL is built this way, it can be used with MapServer to images from
> MrSID quite effectively.
err, a slight correction to this.
The GDAL Library *does* support the MrSID format (if build from a CVS
snapshot linking in the appropriate libraries). I hate it when I get the
main point of a message completely backwards!
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
