[Mapserver-users] mapserver4.0 compilation under w2000
Michael Schulz
mschulz at webgis.de
Mon Aug 25 04:29:21 EDT 2003
Hi Gayathri, Ed,
thanks for your help and answers, it worked with the regex.zip you'd
attached. Perhaps it would be good to add some comments on that problem
to the WIN32 Compilation howto, or even the regex.zip with the Makefile.vc.
To finally get mapserver compiled i had to change the Makefile.vc and
add NODEFAULTLIB:/msvcrtd.lib to the LDFLAGS. Some of the libs were
obviously compiled as Debug and other as release versions. Does that
pose any problems?
Cheers, Michael
Swaminathan, Gayathri wrote:
> Hi Michael,
> This is the regex I have, that Ed had passed on to me., when I was pulling
> straws to fix this problem.
> Try replacing your regex reference with the unzipped dir of the zip file and
> make mapserver.
> HTh,
> Gayathri
> -----Original Message-----
> From: Michael Schulz [mailto:mschulz at webgis.de]
> Sent: Friday, August 22, 2003 1:35 PM
> To: Ed McNierney
> Cc: MapServer Userlist
> Subject: Re: [Mapserver-users] mapserver4.0 compilation under w2000
> Hi Ed, Gayathri,
> But how to make "only" the regex.obj target, there is no such target
> (which Makefile do you mean?) - do i have to edit the makefile.in and
> add such a target manually?!
> Thanks again for your help, i know this is annoying (especially because
> i already managed to do it some time ago ;-))
> Cheers, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
