[Mapserver-users] Problem for draw map whit oracle Spatial
Wilman Rojas
wilmanrojas at geoweb.com.co
Mon Aug 25 11:36:58 EDT 2003
Hi.
My problem is the next:
Apparently all right work. But the image of map is make in blank.
What problem is?
The next is my map file.
MAP
# Start of map file - created Thu Jan 23 11:06:24 2003
NAME "GENERAL"
STATUS ON
EXTENT 1088625.7777777791 934798.2222222225 1106830.2222222236
951182.2222222225
SIZE 500 500
SYMBOLSET "C:\MapServ\Data\varios\symbols.sym"
FONTSET "C:\MapServ\Data\varios\fonts.txt"
IMAGECOLOR 255 255 255
UNITS METERS
# Start of web interface definition
WEB
IMAGEPATH "C:/MapServ/Output/"
IMAGEURL "/output/"
TEMPLATE "C:/mapserv/website/pruebas/index.html"
END
#WEB
# Start of reference map
REFERENCE
STATUS ON
IMAGE "C:/mapserv/data/sigue/gif/tulua.png"
SIZE 100 75
951182.2222222225
COLOR -1 -1 -1
OUTLINECOLOR 255 14 37
END
# Start of legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
POSITION UR
SIZE TINY
COLOR 0 0 89
END
END
# Start of scalebar
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS METERS
INTERVALS 5
#LABEL
SIZE 350 5
LABEL
SIZE SMALL
COLOR 0 0 0
END
END
# Start of layer definitions
LAYER
NAME "Zona rural"
STATUS DEFAULT
CONNECTIONTYPE oraclespatial
CONNECTION "system/geoweb at investigacion"
DATA "GEOM from STATES"
TYPE Polygon
CLASS
NAME "Zonas"
COLOR 215 255 233
OUTLINECOLOR 0 0 0
SIZE 1
END
END
END
thank you for Any help.
Wilman Rojas.
Jefe Investigación y Desarrollo.
Geoweb S.A
www.geoweb.com.co
