[Mapserver-users] PHP/Mapscript w/ PostGIS Query question
Map Surfers
map_surfer at yahoo.com
Tue Aug 26 10:22:08 EDT 2003
I had a post last week regarding using the Rosa applet
query that returned an Apache config error. Since then
I have been debugging. Strangely enough if one layer
(polygon) is queried the results are returned
correctly. However, there change to another layer
(polygon) returns the Apache config error. Yet, change
the layer (point) it returns results.... I am not able
to return on some layers and never for multiple
layers. I ventured down the configuration path bumping
up time-outs and connections, etc. I even doubled
checked the Postgresql access rights the the tables,
all are good. Can anyone think of anything else that I
might have overlooked?
BTW, I am now looking at wrapper/map_query.php file in
the area where "add element to results array for each
result row" portion of the code is because I think
there is something to with this part of the code, but
what????
TIA,
Map Surfer
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
