[Mapserver-users] Unique layer naming for WMS serving
Ed McNierney
ed at topozone.com
Tue Aug 26 15:30:38 EDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C36C08.8794AAC4
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Brent -
=20
We've gone the GROUP route. It works fine, and so far hasn't been an =
issue. We may filter the WMS requests through a PHP script on the front =
end to pull out layers we don't want the user to select, but they'll =
still end up in the GetCapabilities document. I'd be interested, too, =
in hearing from anyone with a better solution.
=20
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242=20
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, August 26, 2003 3:03 PM
To: Daniel Morissette; mapserver-users
Subject: [Mapserver-users] Unique layer naming for WMS serving
Daniel,
=20
I see that the WMS server portion of Mapserver renames the layers (by =
adding _01, _02, etc) to ensure the names are unique. Is there a way to =
prevent that?
=20
=20
Some background...
=20
I've used multiple layer definition for the same data (well almost the =
same data) in a map file to improve performance of rendering raster over =
a wide range of scales. I'll preprocess the data by reampling the high =
resolution raster to medium and low res, then have three layers i the =
map file all named the same but visible only at a scale range approriate =
for their resolution. As the user zooms in, Mapserver automatically =
switches to the higher resolution. Works well with standard Mapserver, =
but using WMS protocol two of the layers get renamed. This means that =
the user now needs to attach three layers and turn them on and off.
=20
Another way I've used the same-layer-name feature is to use the same =
name for point, line, and polygon layers representing one theme such as =
cadastre or structures. But I doubt if WMS clients would tolerate =
that...
=20
I've tried grouping (GROUP and WMS_GROUP_TITLE) but it exposes the =
individual layer names to the user (it may have to do for now).
=20
In my experiments with WMS_GROUP_TITLE, it seems that only one group =
is recognized per map file and that all layers will be included in it. =
Is that true?
=20
Thanks for your comments!.
Brent Fraser
GeoAnalytic Inc.
Tel:(403) 213-2700
www.geoanalytic.com
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1170" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><SPAN class=3D304212919-26082003><FONT face=3DArial color=3D#0000ff =
size=3D2>Brent=20
-</FONT></SPAN></DIV>
size=3D2></FONT></SPAN> </DIV>
size=3D2>We've=20
gone the GROUP route. It works fine, and so far hasn't been an=20
issue. We may filter the WMS requests through a PHP script on the =
front=20
still end=20
up in the GetCapabilities document. I'd be interested, too, in =
hearing=20
from anyone with a better solution.</FONT></SPAN></DIV>
size=3D2> - Ed</FONT></SPAN></DIV>
<P><FONT size=3D2>Ed McNierney<BR>President and Chief =
Mapmaker<BR>TopoZone.com /=20
Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North =
Chelmsford,=20
MA 01863<BR>ed at topozone.com<BR>(978) 251-4242 =
</FONT></P></SPAN></DIV>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV class=3DOutlookMessageHeader dir=3Dltr align=3Dleft><FONT =
face=3DTahoma=20
size=3D2>-----Original Message-----<BR><B>From:</B> Brent Fraser=20
[mailto:bfraser at geoanalytic.com]<BR><B>Sent:</B> Tuesday, August 26, =
2003 3:03=20
PM<BR><B>To:</B> Daniel Morissette; mapserver-users<BR><B>Subject:</B> =
[Mapserver-users] Unique layer naming for WMS =
serving<BR><BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Daniel,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2> I see that the WMS server =
portion of=20
Mapserver renames the layers (by adding _01, _02, etc) to ensure the =
names are=20
unique. Is there a way to prevent that?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Some background...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> I've used multiple layer =
definition for=20
the same data (well almost the same data) in a map file to improve =
performance=20
of rendering raster over a wide range of scales. I'll preprocess =
the=20
data by reampling the high resolution raster to medium and low res, =
then have=20
three layers i the map file all named the same but visible only at a =
scale=20
range approriate for their resolution. As the user zooms in,=20
Mapserver automatically switches to the =
higher resolution. =20
Works well with standard Mapserver, but using WMS =
protocol two of=20
the layers get renamed. This means that the user now needs to =
attach=20
three layers and turn them on and off.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> Another way I've =
used the=20
same-layer-name feature is to use the same name for point, line, and =
polygon=20
layers representing one theme such as cadastre or structures. =
But I=20
doubt if WMS clients would tolerate that...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> I've tried grouping (GROUP and =
WMS_GROUP_TITLE) but it exposes the individual layer names to the user =
(it may=20
have to do for now).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> In my experiments with =
WMS_GROUP_TITLE, it=20
seems that only one group is recognized per map file and that all =
layers will=20
be included in it. Is that true?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your =
comments!.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Brent Fraser</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>GeoAnalytic Inc.<BR>Tel:(403) =
213-2700<BR><A=20
href=3D"mailto:bfraser at geoanalytic.com">bfraser at geoanalytic.com</A><BR><A=
=20
href=3D"http://www.geoanalytic.com">www.geoanalytic.com</A></FONT></DIV><=
/BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C36C08.8794AAC4--
