[Mapserver-users] WMS-GetMap problem in 4.0 (works in 3.6.6)
Daniel Morissette
morissette at dmsolutions.ca
Wed Aug 27 09:48:19 EDT 2003
Frieso ter Haseborg wrote:
> I created two-mapFiles adapted from the "MapServer 3.5 tutorial": One
> mapfile serves as WMS-server-configuration the other one as a
> WMS-client. This configuration works fine with MapServer 3.6.6 but
> failes in MapServer 4.0 with the following error:
> msHTTPExecuteRequests(): HTTP request error. Can't open output file
> ../tmp/106197874319760.img.tmp.
First thing to do would be to check that the "../tmp" directory is
writable. Perhaps ../tmp is not pointing to the location that you think
it points to, so you should probably try using an absolute path for
IMAGEPATH instead of a relative path.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
