[Mapserver-users] Linux/Apache security wrt shapefiles data
    Puneet Kishor
    pkishor at geoanalytics.com
    Wed Aug 27 14:40:02 PDT 2003
Thanks Daniel. That was it. Lesson learned... Keep in mind, all you unix
newbies such as myself. The entire path should be r-x for the apache
user. The easiest way to do that is to "sudo chmod -R 755 yourdirectory"
And next time, instead of spending 20 or so frustrating hours to figure
out such idiosyncracies, just ask Daniel. Merci beaucoup...
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Wednesday, August 27, 2003 4:00 PM
> To: Puneet Kishor
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Linux/Apache security wrt
> shapefiles data
> Did you also make sure that /home/pkishor is at least "r-x" for the
> apache user?  Every directory in the path that leads to the gisdata
> directory has to be at least "r-x" for the apache user.
> Daniel
> pkishor_98 wrote:
> > yes. this is related to MapServer ;-).
> > OS: RH9
> > MapServer 4.0 config-ed and setup correctly.
> > I have my shapefiles under "/home/pkishor/gisdata"
> > and the darn Mapserver refuses to open the shapefiles.
> Error log shows
> > msSHPOpenFile(): Unable to access file. (/home/pkishor/gisdata/bio)
> > I move the shapefiles to "/var/www/html/gisdata" and
> everything works
> > fine.
> > Apache runs as apache:apache, and in both cases I have chown-ed and
> > chgrp-ed the gisdata directory to apache:apache, and also
> chmod-ed it
> > to 777 for good measure. Why is Mapserver unable to read gisdata
> > stored in my home directory? I am new to Linux/RH9, so be gentle in
> > your pedagoguery ;-).
> > Many thanks,
> > Puneet.
More information about the MapServer-users
