[Mapserver-users] Linux/Apache security wrt shapefiles data
Morten Hulden
morten at ngb.se
Wed Aug 27 18:16:40 EDT 2003
On Wed, 27 Aug 2003, Puneet Kishor wrote:
> Thanks Daniel. That was it. Lesson learned... Keep in mind, all you unix
> newbies such as myself. The entire path should be r-x for the apache
> user. The easiest way to do that is to "sudo chmod -R 755 yourdirectory"
> > -----Original Message-----
> > From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> > Sent: Wednesday, August 27, 2003 4:00 PM
> > To: Puneet Kishor
> > Cc: mapserver-users at lists.gis.umn.edu
> > Subject: Re: [Mapserver-users] Linux/Apache security wrt
> > shapefiles data
> > Did you also make sure that /home/pkishor is at least "r-x" for the
> > apache user? Every directory in the path that leads to the gisdata
> > directory has to be at least "r-x" for the apache user.
> > Daniel
rwx-----x is enough for your home directory, but the subdirectory
inside should be r-x for apache.
generally, you need not, and should not give read-permissions to 'others'
to you home directory.
MHu
> > pkishor_98 wrote:
> > > yes. this is related to MapServer ;-).
> > > OS: RH9
> > > MapServer 4.0 config-ed and setup correctly.
> > > I have my shapefiles under "/home/pkishor/gisdata"
> > > and the darn Mapserver refuses to open the shapefiles.
> > Error log shows
> > > msSHPOpenFile(): Unable to access file. (/home/pkishor/gisdata/bio)
> > > I move the shapefiles to "/var/www/html/gisdata" and
> > everything works
> > > fine.
> > > Apache runs as apache:apache, and in both cases I have chown-ed and
> > > chgrp-ed the gisdata directory to apache:apache, and also
> > chmod-ed it
> > > to 777 for good measure. Why is Mapserver unable to read gisdata
> > > stored in my home directory? I am new to Linux/RH9, so be gentle in
> > > your pedagoguery ;-).
> > > Many thanks,
> > > Puneet.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
