[Mapserver-users] spatial from ORACLE 9.2.0.1 support
Hong, Sung-Hyuk
SHHong at mednet.ucla.edu
Thu Aug 28 10:13:51 EDT 2003
Does mapserver support spatial from oracle 9.2.0.1?
Next, I describe my problem.
1. DOWNLOADED the mapserver 4.0 mapserver-4.0.tar.gz
2. COMPILED with oracle 9.2.0.1 in Linux OS
./configure --prefix=/usr --with-proj --with-gdal --with-ogr
--with-wfsclient --with-oraclespatial=/m01/app/oracle/product/9.2.0.1
make
make install
3. INSTALLED the demo and it did run very well
4. CREATED my own ora.map
MAP
EXTENT -2400000 1200000 -1600000 2500000
IMAGECOLOR 200 200 200 #IMAGECOLOR [r] [g] [b]
INTERLACE ON #INTERLACE [on|off]
NAME demo
SIZE 600 600 #SIZE [x][y]
STATUS ON #STATUS [on|off]
UNITS meters #UNITS [feet|inches|kilometers|meters|miles|dd]
LAYER
TYPE point
NAME demo
STATUS default
CONNECTIONTYPE oraclespatial
CONNECTION 'scott/tiger at d2dev'
DATA "GEOMETRY from (select GEOMETRY from PROJ_PATIENT)"
CLASS
OUTLINECOLOR 0 255 0
COLOR 255 0 0
END
END
END
5. TEST from the local hard drive using
./mapserv
"QUERY_STRING=map=/home/nsadmin/servers/server1/pages/itasca/ora.map&mode=ma
p"
FAILED with
msDrawMap(): Image handling error. Failed to draw layer named 'demo'.
msOCIConnect() in msOracleSpatialLayerOpen(): OracleSpatial error.
NOTE: when run against the demo.map, it dump an image to stdout.
Please help!
Thank you in advance,
Sung
