[Mapserver-users] ArcExplorer 4.0.1 as a MapServer WMS client
Brent Fraser
bfraser at geoanalytic.com
Thu Aug 28 11:48:47 EDT 2003
When I was doing my editing, I added the XML header and was slowly morphing
the file to look like one of mine that works, but that wasn't the cause of
the failure. I just tried removing the header and it still works ok.
Sure am looking forward to CITE certified clients and servers....
Brent
----- Original Message -----
To: "Brent Fraser" <bfraser at geoanalytic.com>
Cc: "Eduardo Patto Kanegae" <eduardo at consultoria.eti.br>; "mapserver-users"
<mapserver-users at lists.gis.umn.edu>
Sent: Thursday, August 28, 2003 9:31 AM
Subject: Re: [Mapserver-users] ArcExplorer 4.0.1 as a MapServer WMS client
> Brutal!
> One thing I note though is that your document does not have an XML
> header, which would ordinarily feed the parser the expected character
> set. Perhaps in the absence of a header, it is assuming a very simple
> character set?
> Paul
> Brent Fraser wrote:
> > I did some editing of your xml/gml trying to get ArcExplorer to
recognize
> > it. The message window kept reporting the version as none, even though
the
> > version number seemed ok to me. So I tried tip 2 above and IE pointed
to
> > several parsing errors. Apparently ArcExplorer (and IE) will not allow
> > non-ASCII characters anywhere in the document.
> > When I changed Rincão to Rincao and Talhões to Talhoes, ArcExplorer
worked
> > with it.
> <WMT_MS_Capabilities version="1.1.1" updateSequence="0">
> <!-- MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
> <Service>
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
