[Mapserver-users] ArcExplorer 4.0.1 as a MapServer WMS client
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Thu Aug 28 11:46:55 EDT 2003
Thanks Brant/Paul
I changed ã to a and it works.
But now when I turn on the layer ´Talhoes´ at layer list of ArcExplorer, the message console gaves me:
" Unable to render RendererOp for this operation "
http://www.consultoria.eti.br - BRASIL
***Fim da Mensagem / End of Message ***
On Thu, 28 Aug 2003 08:31:55 -0700, Paul Ramsey <pramsey at refractions.net> escreveu:
> De: Paul Ramsey <pramsey at refractions.net>
> Data: Thu, 28 Aug 2003 08:31:55 -0700
> Para: Brent Fraser <bfraser at geoanalytic.com>
> Assunto: Re: [Mapserver-users] ArcExplorer 4.0.1 as a MapServer WMS client
> Brutal!
> One thing I note though is that your document does not have an XML
> header, which would ordinarily feed the parser the expected character
> set. Perhaps in the absence of a header, it is assuming a very simple
> character set?
> Paul
> Brent Fraser wrote:
> > I did some editing of your xml/gml trying to get ArcExplorer to recognize
> > it. The message window kept reporting the version as none, even though the
> > version number seemed ok to me. So I tried tip 2 above and IE pointed to
> > several parsing errors. Apparently ArcExplorer (and IE) will not allow
> > non-ASCII characters anywhere in the document.
> > When I changed Rincão to Rincao and Talhões to Talhoes, ArcExplorer worked
> > with it.
> <WMT_MS_Capabilities version="1.1.1" updateSequence="0">
> <!-- MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
> <Service>
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
