[Mapserver-users] Re: unsuccessful with gdal-1.1.9 on MacOS X
pkishor_98
pkishor at geoanalytics.com
Thu Aug 28 15:24:13 EDT 2003
William,
Sorry, I didn't reply to your email... actually there is something
funky going on with Yahoo... I didn't see your email until late last
night....
anyway -- thanks for the confirmation that you have gdal working on
Jaguar. I will try out your edit today and if they work for me I will
add them to a wiki document I am preparing for building MS4.
btw, I don't use fink as well, but I recently tried darwinports and
found them to be really good. The nice thing is darwinports are kind
of blessed by Apple (many of Apple's engineers are on that project) so
it likely to have a longer shelf life.
--- In mapserver-users at yahoogroups.com, William K <woklist at c...> wrote:
> I have Mapserver successfully built with gdal on Mac OS X. I started
> putting together some pages on the whole process last week, and may yet
> get them finished and up soon. I don't use fink or darwinports. What
> I've found is that GDAL needs a couple patches and some environment
> variables set to build properly to be usable by other applications.
> Also, are you using the new gcc 3.3 yet?
> Here are the details on the patching:
> edit GDALmake.opt.in:
> on line 17, add '@LDFLAGS@' before -lm. I got this from Fink, but I
> don't remember what it fixes. It should now be:
> LIBS = @LIBS@ @LDFLAGS@ -lm
> on line 204, add '-lgeotiff -ltiff' to CONFIG_LIBS_INS:
> CONFIG_LIBS_INS = -L$(INST_LIB) -lgdal.$(GDAL_VER) -lgeotiff -ltiff
> This tells other software how to link to GDAL, which is probably why
> Mapserver configure is failing.
> edit GNUmakefile:
> add a line before line 21 (for the $(GDAL_SLIB): target):
> $(RANLIB) $(OGRFRMTS_LIB)
> I found that in the middle of building, it stopped because the 'table
> of contents was out of date', and needed an extra ranlib applied to it.
> for the environment and config options:
> % setenv CFLAGS "-O3 -fno-common -no-cpp-precomp"
> % setenv CXXFLAGS "-O3 -fno-common -no-cpp-precomp"
> % ./configure --mandir=/usr/local/share/man --with-libz=/usr
> --with-libtiff=/usr/local \
> -> --with-geotiff=/usr/local --with-jpeg=/usr/local
> --with-gif=/usr/local \
> -> --with-png=/usr/local --without-python --without-ogdi
--with-threads
> then make and install, of course. This works for me. I didn't use any
> internal libs - already have them installed external since I need them
> for GRASS also.
> On Sunday, August 24, 2003, at 11:27 PM, pkishor_98 wrote:
> > [lucknow:~/Projects/mapserver/gdal-1.1.9] pkishor% ./configure --with-
> > libtiff=internal --with-geotiff=internal --without-python
> > and then make produces the following kind of messages --
> > /usr/bin/ld: warning dynamic shared library:
> > /usr/local/lib/libpng.dylib not made a
> > weak library in output with MACOSX_DEPLOYMENT_TARGET environment
> > variable set
> > to: 10.1
> > /usr/bin/ld: warning dynamic shared library: /usr/lib/libz.dylib not
> > made a weak
> > library in output with MACOSX_DEPLOYMENT_TARGET environment variable
> > set to:
> > 10.1
> > /usr/local/lib/libdl.dylib not made a
> > variable set
> > to: 10.1
> > gcc -I/Users/pkishor/Projects/mapserver/gdal-1.1.9
> > mapserver/gdal-1.1.9/port
> > -I/Users/pkishor/Projects/mapserver/gdal-1.1.9/gcore -
> > I/Users/pkishor/Projects/mapserver/gdal-1.1.9/ogr
> > mapserver/gdal-1.1.9/frmts
> > -I/Users/pkishor/Projects/mapserver/gdal-1.1.9/alg -c
> > -Wall -fPIC -O2 gdalwarp.c -o gdalwarp.o
> > g++ gdalwarp.o \
> > -L/Users/pkishor/Projects/mapserver/gdal-1.1.9 -lgdal.1.1
> > -ljpeg -lpng -lz -
> > lm -ldl -lm -o gdalwarp
> > /usr/local/lib/libjpeg.dylib not made a
> > variable set
> > to: 10.1
> > variable set
> > to: 10.1
> > made a weak
> > set to:
> > 10.1
> > variable set
> > to: 10.1
> > and then configuring MapServer --with-gdal results in failure.
> > Will explore more later.
