[Mapserver-users] $shp->{resultscache} empty queryByPoint php mapscript - help!
poff
poff at sixbit.org
Fri Aug 29 16:21:33 EDT 2003
Hello all,
In a quest to get a php mapscript file to locate a click and return a
database value, you will have seen my many postings!
I can get a result, only it's "blank"...
Well I've made a super simplified setup and here it is:
php_mapscript 3.6.6
windows nt/apache 1.3.8 - red hat linux
test.map
NAME TEST_MAP
EXTENT -180 -90 180 90
SIZE 370 331
IMAGETYPE PNG
UNITS DD
WEB
IMAGEPATH "/home/user/tmp/img/"
IMAGEURL "/imgtmp/"
END
LAYER
NAME "QueryLayer"
STATUS OFF
TYPE POINT
TEMPLATE "dummy"
CLASS
NAME "User Marker"
SYMBOL "marker"
COLOR 255 0 0
SIZE 4
END
END
SYMBOL
NAME 'marker'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
END
the php file
<?php
dl("php_mapscript.so");
$map = ms_newMapObj("/home/user/maps/test.map");
$uLayer = $map->getLayerByName("QueryLayer");
$uLayer->set("status",MS_ON);
/* zoom/pan stuff */
if ( isset($_REQUEST["mapa_x"])) {
$zoom=($_REQUEST["zoom"]=="select") ? 0 : $_REQUEST["zoom"];
$extent_to_set = explode(" ",$_REQUEST["extent"]);
$map->setextent($extent_to_set[0],$extent_to_set[1],
$extent_to_set[2],$extent_to_set[3]);
$my_point = ms_newpointObj();
$my_point->setXY($_REQUEST["mapa_x"],$_REQUEST["mapa_y"]);
$my_extent = ms_newrectObj();
$my_extent->setextent($extent_to_set[0],$extent_to_set[1],
$zoom_factor = $zoom*$_REQUEST["power"];
$val_zsize = abs($zoom_factor);
if ($zoom_factor == 0)
$zoom_factor=1;
$map->zoompoint($zoom_factor,$my_point,$map->width,$map->height,
$my_extent);
$val_zsize = $_REQUEST["power"];
$image=$map->draw();
/* sample lat/lon values */
$points=Array(
"-0.1"=>"57",
"33"=>"33",
"66"=>"-55");
foreach ($points as $x => $y) {
$i++;
$oPoint = ms_newPointObj();
$oPoint->setXY($x, $y);
$oPoint->draw($map, $uLayer, $image, 0, "test");
$line = ms_newLineObj();
$line->add($oPoint);
$shp=ms_newShapeObj(MS_SHAPE_POINT);
$shp->add($line);
$shp->{text}="test$i";
$shp->{index}=$i;
$uLayer->addFeature($shp);
/* if we are selecting a click */
if ( isset($_REQUEST["zoom"]) && $_REQUEST["zoom"]=="select") {
$dfKeyMapXMin = $map->extent->minx;
$dfKeyMapYMin = $map->extent->miny;
$dfKeyMapXMax = $map->extent->maxx;
$dfKeyMapYMax = $map->extent->maxy;
$dfWidthPix = doubleval($image->width);
$dfHeightPix = doubleval($image->height);
$nClickGeoX = GMapPix2Geo($_REQUEST['mapa_x'], 0, $dfWidthPix,
$dfKeyMapXMin,
$dfKeyMapXMax, 0);
$nClickGeoY = GMapPix2Geo($_REQUEST["mapa_y"], 0, $dfHeightPix,
$dfKeyMapYMin,
$dfKeyMapYMax, 1);
$my_point->setXY($nClickGeoX,$nClickGeoY);
$uLayer->queryByPoint($my_point, MS_SINGLE, 200);
$results = $uLayer->{resultcache};
$rslt = $uLayer->getResult(0);
$database_id = $rslt->{shapeindex};
echo $database_id;
// always -1
exit;
$image_url=$image->saveWebImage(MS_PNG,1,1,0);
$extent_to_html = $map->extent->minx." ".$map->extent->miny."
".$map->extent->maxx." ".$map->extent->maxy;
<form action="<?php echo $_SERVER["PHP_SELF"]?>" method="GET">
<input type=image name="mapa" width="<?=$map->width?>"
height="<?=$map->height?>" src="<?=$image_url?>">
<br>
<input name=zoom value="1" type="radio"> zoom in<br>
<input name=zoom value="-1" type="radio"> zoom out<br>
<input name=zoom value="0" type="radio"> pan<br>
<input name=zoom value="select" type="radio"> select<br>
<input type="text" size="5" name=power class="theinput" VALUE="<?php echo
$val_zsize?>"> zoom power
<INPUT TYPE=HIDDEN NAME="extent" VALUE="<?php echo $extent_to_html?>">
</form>
<?php
/* from gmap */
function GMapPix2Geo($nPixPos, $dfPixMin, $dfPixMax, $dfGeoMin, $dfGeoMax,
$nInversePix)
$dfWidthGeo = $dfGeoMax - $dfGeoMin;
$dfWidthPix = $dfPixMax - $dfPixMin;
$dfPixToGeo = $dfWidthGeo / $dfWidthPix;
if (!$nInversePix)
$dfDeltaPix = $nPixPos - $dfPixMin;
else
$dfDeltaPix = $dfPixMax - $nPixPos;
$dfDeltaGeo = $dfDeltaPix * $dfPixToGeo;
$dfPosGeo = $dfGeoMin + $dfDeltaGeo;
return ($dfPosGeo);
If you could see anything I'm doing wrong I'd be MOST grateful!!
Thanks,
P
poff at sixbit.org
SDF Public Access UNIX System - http://sdf.lonestar.org
Please do not carbon copy replies to me
