[Mapserver-users] Unique? Was: mapscript - queryByPoint help,
simple Q
Gerry Creager N5JXS
gerry.creager at tamu.edu
Fri Aug 29 19:04:32 EDT 2003
Steve,
Set to positive or negative values? I know it sounds silly, but I tried
to adjust this on one of my projects and I've apparently lost the
correct incantation!
Thanks, Gerry
woodbri at swoodbridge.com wrote:
> poff,
> Do you have TOLERANCE set to a value, if it defaults to 0.0 then it
> is going to be pretty hard to selecet a point.
> -Steve
> On 29 Aug 2003 at 14:08, poff wrote:
>>Hello
>>I know everyone is busy - and thanks a lot for your help.
>>Only, does _no-one_ use querbypoint with php mapscript?
>>It's a great feature if I could get it working, and definitely
>>something to go in Wiki someday!
>>Thanks
>>P
>>On Thu, Aug 28, 2003 at 11:40:42PM +0200, poff wrote:
>>>>The problem is probably in your map file.
>>>>TEMPLATE belongs in the LAYER not the CLASS.
>>>Thanks, I changed this and no change to the outcome.
>>>However, I added the TEMPLATE tag to all of the layers and then
>>>suddenly, on the last layer:
>>>Warning: MapServer Error in msOpenSHPFile(): No (NULL) filename
>>>provided
>>>This is using $mapObj->query...
>>>With the $uLayer->query it just says no records.
>>>Then when I changed $uLayer to the last one they both give the NULL
>>>error.
>>>I'll go bald with all this hair pulling out!
>>>Thanks,
>>>P
>>>>On Thu, 2003-08-28 at 19:15, poff wrote:
>>>>>Hello again
>>>>>I've tried all the list suggestions with the followig code, but
>>>>>am _still_ getting "No Records Found".
>>>>>If anyone could suggest or point out what I'm doing wrong I'd be
>>>>>greatly indebted to them!
>>>>>Here it goes:
>>>>>$map = ms_newMapObj($mapfile);
>>>>>$uLayer = $map->getLayerByName("Points");
>>>>>$uLayer->set("status",1);
>>>>>$image=$map->draw();
>>>>>while () {
>>>>> $oPoint = ms_newPointObj();
>>>>> $oPoint->setXY($geoData['px'], $geoData['py']);
>>>>> $line = ms_newLineObj();
>>>>> $line->add($oPoint);
>>>>> $shp=ms_newShapeObj(MS_SHAPE_POINT);
>>>>> $shp->add($line);
>>>>> $shp->{text}=$geoData['place_name'];
>>>>> $shp->{index}=$i;
>>>>> $uLayer->addFeature($shp);
>>>>> $oPoint->draw($map, $uLayer, $image, 0,
>>>>>$geoData['place_name']);
>>>>>$my_point = ms_newpointObj();
>>>>>$my_point->setXY($_REQUEST["mapa_x"],$_REQUEST["mapa_y"]);
>>>>>$map->queryByPoint($my_point, MS_SINGLE, 20);
>>>>>$uLayer->queryByPoint($my_point,MS_SINGLE,-10); // for good
>>>>>measure ...
>>>>>And the mapfile:
>>>>>LAYER
>>>>> NAME "Points"
>>>>> STATUS ON
>>>>> TYPE POINT
>>>>> LABELCACHE FALSE
>>>>> CLASS
>>>>> NAME "User Marker"
>>>>> SYMBOL "marker"
>>>>> TEMPLATE "dummy"
>>>>> LABEL
>>>>> END
>>>>> END
>>>>>END
>>>>>I'm pretty stumped! I tried by $map-> and $Layer-> queryByPoint
>>>>>to no great joy.
>>>>>Thanks in advance,
>>>>>P
>>>>>poff at sixbit.org
>>>>>SDF Public Access UNIX System - http://sdf.lonestar.org
>>>>>Please do not carbon copy replies to me
>>>>>_______________________________________________
>>>>>Mapserver-users mailing list
>>>>>Mapserver-users at lists.gis.umn.edu
>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>>poff at sixbit.org
>>poff at sixbit.org
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
