[Mapserver-users] MapLab 2.1 -rc3 installation problems.
Martin Kiuru
Martin.Kiuru at Elion.ee
Tue Dec 2 04:32:34 EST 2003
Zak,
Yes, I'am trying to put in work standart Maplab tutorial.
Yestarday I have tried to reinstall all the components using MS2W 0.6.
Maplab works fine now, but following problem is still exist :
When I'am trying to preview map from MapEdit, I have a message "Loading
Java Applet Failed" in IE with
The following errors in Java console :
load: class Rosa2000 not found. java.lang.ClassNotFoundException:
Rosa2000 at sun.applet.AppletClassLoader.findClass(Unknown
Source) at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source) at
java.lang.ClassLoader.loadClass(Unknown Source) at
sun.applet.AppletClassLoader.loadCode(Unknown Source) at
sun.applet.AppletPanel.createApplet(Unknown Source) at
sun.plugin.AppletViewer.createApplet(Unknown Source) at
sun.applet.AppletPanel.runLoader(Unknown Source) at
sun.applet.AppletPanel.run(Unknown Source) at
java.lang.Thread.run(Unknown Source) Caused by: java.io.IOException:
open HTTP connection failed. at
sun.applet.AppletClassLoader.getBytes(Unknown Source) at
sun.applet.AppletClassLoader.access$100(Unknown Source) at
sun.applet.AppletClassLoader$1.run(Unknown Source) at
java.security.AccessController.doPrivileged(Native Method) ... 10
more
If the ROSA is disabled, all seems to be ok, in MapBrowser ROSA works
fine.
Thanks for your help !
Martin
-----Original Message-----
Sent: Monday, December 01, 2003 5:45 PM
To: Martin Kiuru
Subject: Re: [Mapserver-users] MapLab 2.1 -rc3 installation problems.
Martin,
Is this just the standard tutorial file you are using? I can't recreate
your problem here with that. If it's a custom mapfile, maybe you could
send it to me, or send a limited file that exhibits the problem.
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
On Dec 1, 2003, at 1:38 AM, Martin Kiuru wrote:
> I'm using IE 6.0.2800.1106CO
> Yes, fonts referenced by mapfile are present. Also, I have already
> tried
> to change paths to absolute - unfortunately, it does not change
> anything...
> Thanks for your reply,
> Martin Kiuru.
> From: Zak James [mailto:zak-ms at hoppsan.org]
> Sent: Friday, November 28, 2003 6:43 PM
> To: Martin Kiuru
> Cc: mapserver-users at lists.gis.umn.edu
> Can you provide some additional information?
> What web browser are you using to view the map browser?
> Can you check that the fonts file referenced by your map is present?
> Also, make sure that any fonts required by the layers in your map file
> are referenced in that fonts file.
> If all of that looks ok, you can try making the paths to the symbol
> and fonts files in the map absolute rather than relative (e.g. ./data
> would become /<maplab-dir>/data). On some platforms, Mapserver 4.0 has
> problems with relative paths.
> Ideally, these problems would result in more instructive error
> messages. We hope to be able to address that before the final release
> of 2.1.
> Zak James
> On Nov 28, 2003, at 8:22 AM, Martin Kiuru wrote:
>> Hi,
>> I have a problem with Maplab installation and tutorial project.
>> Maplab
>> generally works, but with the following problems :
>> - Browser main window shows only a white screen - not map. Only after
>> some movements/zooms around the map image appears.
>> - Map preview not working - appears new window with following errors
>> Warning: [MapServer Error]: msGetLabelSize(): Could not find/open
>> font
>> in C:\Program Files\Apache
>> Group\Apache2\htdocs\maplab\htdocs\mapedit\preview.php on line 469
>> Fatal
>> error: Call to a member function on a non-object in C:\Program
>> Files\Apache Group\Apache2\htdocs\maplab\htdocs\mapedit\preview.php
>> on
>> line 474
>> -Following error appears in map browser
>> Error Parsing tutorial.map
>> Description
>> Could not find/open font in /maplab/htdocs/common/wrapper/drawmap.php
>> Please advice! Here is the configuration of my test server :
>> Windows 2000 SP4
>> MapLab (2.1 -rc3)
>> Mapserver 4.0
>> Apache 2.0.48
>> PHP 4.3.4
>> Martin Kiuru
> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
