[Mapserver-users] recalculate scale with mapscript
Sean Gillies
sgillies at frii.com
Tue Dec 2 09:58:49 EST 2003
On Tuesday, December 2, 2003, at 06:54 AM, Michael Schulz wrote:
> Hi,
> how can i trigger the recalculation of the current scale for a
> mapscript mapObj if i don't want to draw/prepareImage my map before?
> In this special case, i want to change the mapsize and then reassign
> the scale the mapObj had before and then draw the image (so in my
> application, when changing the mapsize the scale stays the same but
> the extent changes).
> Cheers, Michael
> Michael Schulz in medias res
> Dipl.-Geologe Gesellschaft für
> Informationstechnologie mbH
> In den Weihermatten 66
> 79108 Freiburg
> 0761 55695-95 (Fax 96)
> mschulz at webgis.de www.webgis.de/www.zopecms.de
Michael,
There's a setExtent extension to mapObj in the 4.1 (CVS) MapServer.
Since
we had frozen the features of 4.0, I did not commit it to that source
branch.
You are welcome to paste it into your mapscript.i and re-build, it
doesn't
depend on any other code in 4.1.
cheers,
Sean
// Modeled after PHP-Mapscript method
// Adjusts map extents and sets map scale
// Difference from PHP-Mapscript is the rectObj arg is optional,
default
// value is NULL, in which case the current extent values will be
// used, making this function useful to set the scale of a new mapObj.
void setExtent(rectObj *rect=NULL) {
if (rect == NULL) {
// Leave the current extents alone
else {
self->extent.minx = rect->minx;
self->extent.miny = rect->miny;
self->extent.maxx = rect->maxx;
self->extent.maxy = rect->maxy;
self->cellsize = msAdjustExtent(&(self->extent), self->width,
self->height);
msCalculateScale(self->extent, self->units, self->width,
self->height,
self->resolution, &(self->scale));
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
