[Mapserver-users] Segmentation Fault -- reference image -- PHP
Daniel Morissette
morissette at dmsolutions.ca
Tue Dec 2 15:58:12 EST 2003
Ed Martin wrote:
> i am using the map file and map stuff from the cvs mapserver (did not
> compile from cvs, i used the stable version 4.0.1) and when i try to get
> the reference image using a very simple script i get the jpeg header an
> then a segmentation fault when run in the command line and a blank page
> when in a browser, turning off the jpeg header still gives me a blank page
> here is the php file i am using
It could be that your php_mapscript.so and your PHP itself were compiled
with conflicting versions of GD and/or freetype. It could also be that
you have multiple versions of GD on your system and the wrong one is
loaded at runtime.
Use phpinfo() to see if PHP has GD enabled, if it does then either
disable the PHP GD extension or make sure that both PHP and MapScript
use the same GD version. Also make sure that there is only one copy of
libgd.so and of the GD headers on your system.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
