[Mapserver-users] Re: Oriented arrows mapserver
woodbri at swoodbridge.com
Tue Dec 9 14:31:25 EST 2003
Hi all,
Another idea might be to create a truetype font symbol to use when
rendering the line so you could apply arrows along the line like
railroad ties. You would have to experiment a little to get the right
look.
A general related problem is how to specify the location of symbols
like this. It would be nice to be able to assume the line is in unit
space (ie: 0.0 - 1.0 from start to end) and then be able to say you
want to apply a symbol or label at some location(s) along that unit
space of the line/polyline. Then something like LOCATE_AT 0.0, 0.5,
1.0 would place the symbol at the beginning (0.0), the mid-point
(0.5) and the end (1.0)
Or for street segments that have a direction attribute, I would like
to style them with an indication of street direction, like an arrow
in either the from-to direction of the to-from direction. This could
be sorted out using classes if I can generate the arrow to align with
the street.
-Steve W.
On 9 Dec 2003 at 17:01, Michael Schulz wrote:
> Hi,
> perhaps someone on the list has more experience on the problem below (it
> usually gives a lot more answers when posting to the list).
> My guess would be you could try and use the street data layer labeling
> for drawing arrow symbols. Let mapserver rotate the labels based on the
> direction of each line segment (ANGLE auto, Mapserver can only rotate
> labels for line data automatically), and use the static text "->" (your
> arrow character) as label text. Imagine this as instead of labeling with
> the street name rotated along the street direction the streets are
> labelled with the arrow.
> HTH, Michael
> Ballini Yvain schrieb:
> > Dear Michael,
> > I would like to use an arrow symbol which follows the direction of my
> > street layer. I still have the shapefile of the arrows but when I choose
> > a symbol in the layer for visualizing the arrows, it doesn't follow the
> > street direction.
> > The symbol is this one:
> > SYMBOL
> > NAME "arrow"
> > TYPE truetype
> > FONT arial
> > CHARACTER "->"
> > #POSITION CC
> > GAP -10
> > END
> > And the arrow-layer is this one:
> > LAYER
> > NAME freccie_navtech
> > PROJECTION
> > "proj=longlat"
> > "ellps=intl"
> > "no_defs"
> > END
> > STATUS OFF
> > DATA arrow_font_point
> > TYPE POINT
> > CLASS
> > STYLE
> > SYMBOL 'arrow'
> > size 20
> > COLOR 245 88 128
> > ANTIALIAS TRUE
> > END
> > END
> > END
> > If I change the position option in the symbol definition, it doesn't
> > change anything for the orientation.
> > Do you know where I'm wrong ??
> > Thank you very much.
> > Yvain Ballini.
> Michael Schulz in medias res
> Dipl.-Geologe Gesellschaft für
> Informationstechnologie mbH
> In den Weihermatten 66
> 79108 Freiburg
> 0761 55695-95 (Fax 96)
> mschulz at webgis.de www.webgis.de/www.zopecms.de
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
