[Mapserver-users] Storing database connections in a CGI session
Bart van den Eijnden
bartvde at xs4all.nl
Tue Dec 9 14:56:13 EST 2003
Hi Doug,
are you absolutely convinced there is no caching involved with ArcIMS?
All the performance tests we did against ArcIMS showed a huge difference
between the maximum response time, and the average response time, which
indicates caching in my opinion. This even was the case with shapefiles
where no database connection is needed.
Best regards,
Bart
On 09 Dec 2003 11:22:22 -0800, Doug Cates <doug at moximedia.com> wrote:
> Richard, Bart,
> I'm also VERY interested in this, as I'm hoping to set up a MapServer /
> SDE implementation early in the new year. Can you send me some
> information on your testing too, Richard?
> As far as ArcIMS goes, I know for sure that it sets up multiple
> connections to SDE for each ArcIMS service when the service is created,
> and keeps them open until the ArcIMS service is shut down. I don't
> believe that there is any caching taking place.
> Is there any chance that something can be built right into MapServer to
> do something similar, opening a connection pool when the first SDE map
> is requested, and re-using the connections if they are present?
> Doug
> On Tue, 2003-12-09 at 10:45, Bart van den Eijnden wrote:
>> Hi Richard,
>> what is the absolute difference in performance (time) between Mapserver
>> en
>> ArcIMS? And can you tell some more about how you did the tests (number
>> of
>> concurrent users, which tool etc.)?
>> I think the difference is not only in the database connection, but also
>> in
>> the caching of data. Although I do not know how ArcIMS works exactly
>> behind the scenes ofcourse.
>> An alternative to CGI sessions is the fastcgi approach. Frank Warmerdam
>> did some work on this a few months ago, but I don't know if there any
>> useable results.
>> See also:
>> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?FastCGI
>> Best regards,
>> Bart
>> On Tue, 9 Dec 2003 19:29:32 +0100, Richard Holzmeier
>> <Richard.Holzmeier at epost.de> wrote:
>> > Currently i am testing MapServers load performance against ArcIMS
>> using
>> > SDE
>> > and OracleSpatial database connections. ArcIMS displaces MapServer
>> with a
>> > performance rate up to 7:1, certainly due to the overhead of creating
>> a
>> > new
>> > session with every request. I´m thinking about using CGI sessions to
>> > store
>> > opened database sessions for a while using a library such as
>> CGI::SESSION
>> > (http://search.cpan.org/~sherzodr/). Unfortunately i´m fairly new with
>> > C/C++
>> > and Perl and have no idea of the complexity or possibility to
>> implement
>> > this.
>> > If anybody has, i will appreciate responses of any kind. Thanks in
>> > advance,
>> > Richard
>> > _______________________________________________
>> > Mapserver-users mailing list
>> > Mapserver-users at lists.gis.umn.edu
>> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
