[Mapserver-users] layer not drawn in utm projection
Ed McNierney
ed at topozone.com
Thu Dec 11 10:48:13 EST 2003
Niklas -
I doubt this is a bug. I am assumeing that you made the change by changing (or adding) a PROJECTION block at the top level of your map file to specify UTM output. Did you - at the same time - insert a PROJECTION block for the ocean rectangle to indicate that it is in decimal degrees, not UTM?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: niklas wörmann [mailto:nwoe at privat.utfors.se]
Sent: Thursday, December 11, 2003 10:07 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] layer not drawn in utm projection
Hi!
i think i have found a bug.
i have my mapfile set up so it will render an ocean rectangle as a bottom
layer, and then the land layers on top of this.
( i know, you can use imagecolor for this too, but for various reasons i
need the rectangle to be there)
the layer shows up fine when using proj=latlong
but will not show up when using UTM.
i have tried outputting both jpg and swf, and neither one shows the ocean
rectangle when using proj=utm.
regards
niklas woermann
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
