[Mapserver-users] layer not drawn in utm projection
Debbie Pagurek
pagurekd at agr.gc.ca
Thu Dec 11 11:22:39 EST 2003
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
--=_D38D39C5.1F7E3D90
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: quoted-printable
I don't have a lot of time to look at this right now,
but my first reactions are that maybe the units should me set to METERS.
Also, you might want to try an epsg code for your utm projection,
instead of setting each parameter.
Debbie
>>> "niklas w=F6rmann" <nwoe at privat.utfors.se> 12/11/03 10:51AM >>>
Hi!
i doubt that the map file has a great deal to do with it,
here it is..
i set the extent etc from cgi-parameters
NAME M6H2_
units kilometers
SIZE 800 600
SHAPEPATH "c:/PF/AG/apache2/htdocs/ms/data"
FONTSET "c:/PF/AG/apache2/htdocs/ms/fonts/fonts.list"
SYMBOLSET "c:/PF/AG/apache2/htdocs/ms/symbols/symbols35.sym"
IMAGETYPE swf
IMAGECOLOR 255 169 191
WEB
TEMPLATE s6dev.html
IMAGEPATH "c:/PF/AG/apache2/htdocs/tmp/"
IMAGEURL "/tmp/"
END
PROJECTION
"proj=3Dlatlong"
"ellps=3DWGS84"
"lat_0=3D0"
"lon_0=3D0"
END
above projection works fine,
but not the one below, regardless of zone
PROJECTION
"proj=3Dutm"
"zone=3D30"
"ellps=3DWGS84"
"datum=3DWGS84"
END
this is the layer
LAYER=20
PROJECTION
"proj=3Dlatlong"
"ellps=3DWGS84"
"lat_0=3D0"
"lon_0=3D0"
END
NAME baks
DATA drainage/world_oceans_rectangle
STATUS default
TYPE polygon
CLASS
NAME "muts"
COLOR 151 169 191
END
END # end of layer object
it really is strange, i will check to see if i can get it not to draw
using some other projections
niklas woermann
Content-Type: text/html; charset=ISO-8859-1
Content-Transfer-Encoding: 8bit
Content-Description: HTML
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 6.00.2800.1276" name=GENERATOR></HEAD>
<BODY style="MARGIN-TOP: 2px; FONT: 10pt Arial; MARGIN-LEFT: 2px">
<DIV>I don't have a lot of time to look at this right now,</DIV>
<DIV>but my first reactions are that maybe the units should me set to METERS.
</DIV>
<DIV>Also, you might want to try an epsg code for your utm projection, instead
of setting each parameter.</DIV>
<DIV> </DIV>
<DIV>Debbie<BR><BR>>>> "niklas wörmann" <nwoe at privat.utfors.se>
12/11/03 10:51AM >>><BR></DIV><FONT face=Arial size=2>
<DIV>Hi!</DIV>
<DIV>i doubt that the map file has a great deal to do with it,</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>here it is..</DIV>
<DIV> </DIV>
<DIV>i set the extent etc from cgi-parameters</DIV>
<DIV> </DIV>
<DIV>NAME M6H2_<BR><BR>units kilometers</DIV>
<DIV>SIZE 800 600</DIV>
<DIV> </DIV>
<DIV><BR>SHAPEPATH "c:/PF/AG/apache2/htdocs/ms/data"<BR>FONTSET
"c:/PF/AG/apache2/htdocs/ms/fonts/fonts.list"<BR>SYMBOLSET
"c:/PF/AG/apache2/htdocs/ms/symbols/symbols35.sym"</DIV>
<DIV> </DIV>
<DIV>IMAGETYPE swf<BR>IMAGECOLOR 255 169 191</DIV>
<DIV><BR>WEB<BR> TEMPLATE s6dev.html<BR> IMAGEPATH
"c:/PF/AG/apache2/htdocs/tmp/"<BR> IMAGEURL "/tmp/"<BR>END</DIV>
<DIV> </DIV>
<DIV>PROJECTION<BR> "proj=latlong"<BR> "ellps=WGS84"<BR>
"lat_0=0"<BR> "lon_0=0"<BR>END</DIV>
<DIV>above projection works fine,</DIV>
<DIV>but not the one below, regardless of zone</DIV>
<DIV> </DIV>
<DIV>PROJECTION</DIV>
<DIV> </DIV>
<DIV>"proj=utm"<BR>"zone=30"<BR> "ellps=WGS84"<BR>"datum=WGS84"</DIV>
<DIV> </DIV>
<DIV>END</DIV>
<DIV> </DIV>
<DIV>this is the layer</DIV>
<DIV>LAYER <BR>PROJECTION<BR> "proj=latlong"<BR>
"ellps=WGS84"<BR> "lat_0=0"<BR> "lon_0=0"<BR>END<BR> NAME
baks<BR> DATA drainage/world_oceans_rectangle<BR> STATUS
default<BR> TYPE polygon<BR> CLASS<BR> NAME
"muts"<BR> COLOR 151 169 191<BR> END<BR>END # end of
layer object</DIV>
<DIV> </DIV>
<DIV>it really is strange, i will check to see if i can get it not to draw using
some other projections</DIV>
<DIV> </DIV>
<DIV>niklas woermann</DIV></FONT></BODY></HTML>
--=_D38D39C5.1F7E3D90--
