[Mapserver-users] postgres query speed problems
Grant Howarth
Grant.Howarth at divestco.com
Thu Dec 11 13:20:03 EST 2003
I am using a postgres database to mapdata. The mapping works without any problems and has good speed. When i swich to mode=nquery and try and query for the results of an area it takes over a minute to respond. I don't understand why there such a speed problem when querying.
my cgi call:
http://207.34.103.9/cgi-bin/mapserv?mode=nquery&map=/mapfiles/idc_canada-query.map&imgext=-114.39043+55.92687+-114.03728+56.12285&mapsize=373+207&imgbox=203+47+214+57&layers=wells
my idc_canada-query.map file:
NAME test
LAYER
NAME "wells"
TYPE point
STATUS off
MAXSCALE 8
CONNECTIONTYPE postgis
CONNECTION "user=myuser dbname=idc host=idcmap port=5432"
DATA "the_geom from gen_well"
TEMPLATE "./test.html"
END
my test.html file:
{item: wells [uwi] }
when ran, i do get the following results but it takes about a minute for it to come back:
{item: wells 100020208202W502 } {item: wells 100020208202W500 }
my table does have geometry columns
there is an index on the uwi (primary key)
there is an index on oid
there is an index on the_geom
I managed to capture the query that i think mapserv is running and ran it myself and it responded in less than a second. So it seems like mapserv is doing something after with the data that is taking along time?
Any sugestions would be greatly appreciated.
Thanks, Grant
