[Mapserver-users] [Fwd: I: compiling mapserver 4.0 with gdal support on VC7]
Stephen Clark
stephen.clark at focus.ca
Fri Dec 12 11:08:10 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0037_01C3C087.14F081D0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
Have you run vcvars32.bat before the nmake /f makefile.vc ?
I have also attached my nmake.opt from my "mapserver" directory as a
reference.
Stephen
----- Original Message -----
To: "MapServer Userlist" <mapserver-users at lists.gis.umn.edu>
Sent: Friday, December 12, 2003 12:22 AM
Subject: [Mapserver-users] [Fwd: I: compiling mapserver 4.0 with gdal
support on VC7]
-------- Ursprüngliche Nachricht --------
Betreff: I: compiling mapserver 4.0 with gdal support on VC7
Datum: Thu, 11 Dec 2003 16:21:22 +0100
Von: Ballini Yvain <Ballini.Yvain at seat.it>
An: Michael Schulz <mschulz at webgis.de>
Hi Michael ,
I'm trying to recompile mapserver 4.0 with OGR support (on Windows XP
with VC7).
Without the gdal support, it's everything ok but adding the gdal support
introduces a lot of problem during the recompilation of mapserver.
When I run the makefile.vc of mapserver, it gives me the following
errors for gdal 1.1.9:
cpl.lib(cpl_error.obj) : error LNK2019: unresolved external symbol
__imp___vsnpr intf referenced in function _CPLDebug
cpl.lib(cpl_string.obj) : error LNK2019: unresolved external symbol
__imp___vsnp rintf referenced in function _CSLSave
cpl.lib(cpl_vsisimple.obj) : error LNK2019: unresolved external symbol
__imp__fp uts referenced in function _VSIFPuts
__imp__mk dir referenced in function _VSIMkdir
OLDNAMES.lib(mkdir.obi) : error LNK2001: unresolved external symbol
__imp__mkdir
__imp__rm dir referenced in function _VSIRmdir
OLDNAMES.lib(rmdir.obi) : error LNK2001: unresolved external symbol
__imp__rmdir
__imp__strer ror referenced in function _CSLSave
__imp___errn o referenced in function _CSLSave
cpl.lib(cpl_dir.obj) : error LNK2019: unresolved external symbol
__imp___findclo se referenced in function _CPLReadDir
__imp___findnex t referenced in function _CPLReadDir
__imp___findfir st referenced in function _CPLReadDir
__imp___mkdi r
__imp___rmdi r mapserv.exe : fatal error LNK1120: 11 unresolved
externals NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
Has you any idea about the mistake ?
Thanks.
Yvain Ballini.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: application/octet-stream;
name="nmake.opt"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="nmake.opt"
# nmake.opt - MapServer 4.x configuration for MSVC++
# This VC++ configuration is used in building MAPSERVER.LIB, =
MAPSERV.EXE,
# and the other MapServer command-line programs.
# To use the makefile:
# - Open a DOS prompt window
# - Run the VCVARS32.BAT script to initialize the VC++ environment =
variables
# - Start the build with: nmake /f makefile.vc
# $Id: nmake.opt,v 1.2 2003/06/13 13:28:38 assefa Exp $
# Contents:
# Section I: Mapserver Options (you may want to edit)
# Section II: Support Libraries (you must edit)
# Section III: Debug Flags (no need to edit)
# Section IV: Variable Setup (should not need to edit)
# Section V: UMN GIS System Setup (should not need to edit)
# Section VI: Collect compiler flags
# Input raster format options:
# The lite version of mapserver 4.x supports only PNG and JPEG data for =
input.
# If you wish to support any of the following raster formats you will =
need
# the GDAL support library from http://www.remotesensing.org/gdal.
# Once you have the library, set the flag below to compile with GDAL and
# provide the full path to GDAL project directory
# Format Name
# Arc/Info ASCII Grid AAIGrid
# Arc/Info Binary Grid (.adf) AIG
# Microsoft Windows Device Independent Bitmap (.bmp) BMP
# BSB Nautical Chart Format (.kap) BSB
# CEOS (Spot for instance) CEOS
# First Generation USGS DOQ (.doq) DOQ1
# New Labelled USGS DOQ (.doq) DOQ2
# Military Elevation Data (.dt0, .dt1) DTED
# ERMapper Compressed Wavelets (.ecw) ECW
# ESRI .hdr Labelled EHdr
# ENVI .hdr Labelled Raster ENVI
# Envisat Image Product (.n1) Envisat
# EOSAT FAST Format FAST
# FITS (.fits) FITS
# Graphics Interchange Format (.gif) GIF
# Arc/Info Binary Grid (.adf) GIO
# GRASS Rasters GRASS
# TIFF / GeoTIFF (.tif) GTiff
# Hierarchical Data Format Release 4 (HDF4) HDF4
# Erdas Imagine (.img) HFA
# Atlantis MFF2e HKV
# Japanese DEM (.mem) JDEM
# JPEG2000 (.jp2, .j2k) JPEG2000
# JPEG2000 (.jp2, .j2k) JP2KAK
# NOAA Polar Orbiter Level 1b Data Set (AVHRR) L1B
# Atlantis MFF MFF
# NITF NITF
# OGDI Bridge OGDI
# PCI .aux Labelled PAux Yes
# Netpbm (.ppm,.pgm) PNM Yes
# USGS SDTS DEM (*CATD.DDF) SDTS
# SAR CEOS SAR_CEOS
# USGS ASCII DEM (.dem) USGSDEM
# X11 Pixmap (.xpm) XPM
GDAL=3D-DUSE_GDAL
GDAL_DIR=3Dc:\projects\mapserver-4.0\gdal-1.1.9
# Input vector format options
# The lite version of Mapserver 4.x only suports ESRI shapefiles for =
input.
# If you wish to support any of the following vector formats you will =
need
# the GDAL support library with OGR from =
# Once you have the library, set the flag below to compile with OGR and
# Format Name
# Arc/Info Binary Coverage
# FMEObjects Gateway
# IHO S-57 (ENC)
# Mapinfo File
# Microstation DGN
# OGDI Vectors
# Oracle Spatial
# PostgreSQL
# SDTS
# UK .NTF
# U.S. Census TIGER/Line
OGR=3D-DUSE_OGR
#ECW support
#ECW is one of the formats supported through GDAL. If you have built
#gdal with ECW support, you need to link it with the ECW librarires.
#uncommnet the following lines to have the ECW support.
ECW_DIR=3D C:\Progra~1\Earthr~1\ECW_SDK
#Xerces support
#If GDAL was compoiled with the Xerces support, you need to use the=20
#xerces library. #uncommnet the following line to have the Xerces =
support
#XERCES_DIR =3D c:\projects\xerces-c1_6_0-win32
# Tiff Input
#=20
# Tiff input is also available through GDAL. If you wish to build to =
support
# TIFF input without GDAL you will need to unccomment the following flag =
# and set the full path to the project directory containing libtiff.
# See http://www.libtiff.org/ for support library
TIFF=3D-DUSE_TIFF
TIFF_DIR=3Dc:/projects/mapserver-4.0/tiff-v3.6.0/libtiff
#TIFF_DIR=3Dc:/projects/mapserver-4.0/gdal-1.1.9/frmts/gtiff/libtiff
# JPEG Input:
# JPEG input for raster layers is also available through GDAL, If you =
wish=20
# to build support for JPEG without GDAL, uncomment the following flag
# and provide the full path to the jpeg support library project =
directory.
# See http://www.ijg.org/ for support library.
#JPEG=3D-DUSE_JPEG
#JPEG_DIR=3De:/mapserver4/gdal/frmts/jpeg/libjpeg
# Output format options:
# If you wish to allow JPEG output maps, uncomment the following flag
directory.
OUTPUT_JPEG=3D-DUSE_GD_JPEG
#JPEG_DIR=3Dc:/projects/mapserver-4.0/gdal-1.1.9/frmts/jpeg/libjpeg
JPEG_DIR=3Dc:/projects/mapserver-4.0/jpeg-6b/
# If you wish to allow PNG output maps, uncomment the following flag
# and provide the full path to the png and zlib support library project
# directories.
# See http://www.libpng.org/pub/png/libpng.html for support library.
# See http://www.gzip.org/zlib/ for support library.
OUTPUT_PNG=3D-DUSE_GD_PNG
PNG_DIR=3Dc:/projects/mapserver-4.0/libpng
ZLIB_DIR=3Dc:/projects/mapserver-4.0/zlib
# If you wish to allow Windows BMP output maps, uncomment the following =
flag.
#OUTPUT_WBMP=3D-DUSE_GD_WBMP
# If you wish to have FLASH output, uncomment the following flag and =
provide
# the full path to the MING support library project directory.
# See http://ming.sourceforge.net/ for support library.
#MING=3D-DUSE_MING_FLASH
#MING_DIR=3Dc:/projects/ming-0.2a
# If you wish to have PDF output, uncomment the following flag and =
provide the
# full path to the PDF support library project directory.
# See http://www.pdflib.com/ for support library.
PDF=3D-DUSE_PDF
PDF_DIR=3Dc:/projects/pdflib-5.0.2
# Annotation fonts.
# If you wish to annotate your maps with true type fonts unccomment the
# following flag. Provide the full path to the FreeType 2.x external
# supprt library. See http://www.freetype.org for support library.
ANNOTATION_FT=3D-DUSE_GD_FT
FT_DIR=3Dc:/projects/mapserver-4.0/freetype-2.1.4
# Direct connectivity to Postgresql PostGIS.
#=20
# To turn on direct connectivity to Postgresql PostGIS uncomment the =
following
# flag and set the full path name to the project directory for the=20
# Postgresql native Win32 client library.
# See http://www.postgresql.org for support library.
#POSTGIS =3D-DUSE_POSTGIS
#POSTGIS_DIR =3Dc:/projects/postgresql-7.3.4
# Direct connectivity to ArcSDE.
#=20
# To turn on direct connectivity to ArcSDE uncomment the following
# flag and set the full path name to the project directory for ArcSDE.
# Since ESRI includes the version number in the name of their libraries
# you may need to change that number in Section III of this =
configuration
# file.
# See http://www.esri.com/software/arcgis/arcinfo/arcsde/index.html for
# support library
#SDE_OPT=3D-DUSE_SDE -DWIN32
#SDE_DIR=3Dc:/my_path_to/arcsde
# EPPL7 Support
# This activates ERDAS as well. It is included in the distribution.=20
# Probably the best raster alternative if
# you've got EPPL7 laying around. See http://www.lmic.state.mn.us/ for=20
# more information.
# Uncomment out the following flag and set the full path name to the
# epplib.obj file.
EPPL=3D-DUSE_EPPL
EPPL_OBJ=3Dc:/projects/mapserver-4.0/epplib.obj
# If you want to ignore missing datafile errors uncomment the following
# line. This is especially useful with large tiled datasets that may not
# have complete data for each tile.
IGNORE_MISSING_DATA=3D-DIGNORE_MISSING_DATA
# If you want antialiasing (note that It requires gd2)
#USE_GD_ANTIALIAS=3D-DUSE_GD_ANTIALIAS
# Use this flag to compile with WMS Server support.
# To find out more about the OpenGIS Web Map Server Specification go to
# http://www.opengis.org/
WMS=3D-DUSE_WMS_SVR
# Use this flag to compile with WMS Client support. WMS Client support
# allows you to pull layers from other OGIS WMS servers on the interent =
and
# incorporate them into your map.
# you need the libcurl library from http://curl.haxx.se/library/c/
# Set the full path to the curl project directory.
# You will also need to set the full path to the Microsoft Visual C++ =
windows
# socket library.
WMSCLIENT=3D -DUSE_WMS_LYR
CURL_DIR=3Dc:/projects/mapserver-4.0/curl-7.10.7
#WINSOCK_LIB =3D "C:\Progra~1\Microsoft Visual =
Studio\VC98\Lib\WSOCK32.LIB"
WINSOCK_LIB =3D "C:\Program files\Microsoft Visual Studio .NET =
2003\vc7\PlatformSDK\Lib\WSOCK32.LIB"
# Use -DUSE_WFS_SVR to compile with WFS server support, requires OGR and =
PROJ4
# Use -DUSE_WFS_LYR to compile with WFS client support, requires libcurl
#WFS=3D-DUSE_WFS_SVR
#WFSCLIENT=3D -DUSE_WFS_LYR
# Reprojecting.
# If you would like mapserver to be able to reproject data from one
# geographic projection to another, uncomment the following flag
# Proj.4 distribution (cartographic projection routines).=20
# Not required for normal use. (EXPERIMENTAL)
# For PROJ_DIR use full path to Proj.4 distribution
PROJ=3D-DUSE_PROJ -DUSE_PROJ_API_H
PROJ_DIR=3Dc:\projects\proj-4.4.7
# PHP Mapscript.
# If you plan to build PHP mapscript uncomment the following flag and
# set the full path to the PHP project directory
PHP=3D1
PHP_DIR=3Dc:\projects\php-4.3.2
# Apparently these aren't as commonplace. Edit the
# following line to reflect the missing functions on your platform.
#STRINGS=3D-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRDUP
# Section II: External Support Libraries
# You will need to set the paths to various support library projects
# that you have compiled.
# GD Library. =20
# Mapserver 4.x only supports GD 2.x and greater.
# Sorry no more GIF support. If you need GIF support you will
# need to run Mapserver 3.6.x with GD 1.2.
# GD is a required support library for MapServer 4.x.
# Enter the full path to your GD 2.x project directory
# Note : A patched version of GD that supports GIF, JPEG, PNG and WBMP =
can be=20
# downloaded from http://www.rime.com.au/gd/. If you are using this =
library,
#you should uncomment the following line
#OUTPUT_GIF=3D-DUSE_GD_GIF -DGD_HAS_GDIMAGEGIFPTR
GD_DIR=3Dc:/projects/mapserver-4.0/gd-2.0.15
# REGEX Libary
#=20
# VC++ does not include the REGEX library... so we must provide our one.
# The following definitions will try to build GNU regex-0.12 located in =
the
# regex-0.12 sub-directory.
# If it was not included in the source distribution, then you can get it =
# ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
# Provide the full path to the REGEX project directory
# You do not need this library if you are compiling for PHP mapscript.
# In that case the PHP regex library will be used instead
!IFNDEF PHP
REGEX_DIR=3Dc:/projects/mapserver-4.0/regex-0.12
!ENDIF
# Section III: Debug flags
# Should not need to be updated.
# DEBUG Build flags
# Set the DEBUG flag if you wish to make a debug build
DEBUG=3D/DDEBUG
# Set the Warning level for the compiler (defaults to W1)
WARNING_LEVEL=3D/W3
# Set the linker debug option
LDEBUG=3D/debug
# Proj.4 include and library
!IFDEF PROJ_DIR
PROJ_INC=3D-I$(PROJ_DIR)/src
PROJ_LIB=3D$(PROJ_DIR)/src/proj.lib
!ENDIF
# CURL include and library
!IFDEF WMSCLIENT
CURL_INC =3D -I$(CURL_DIR)/include
CURL_LIB =3D $(CURL_DIR)/lib/debug/libcurl.lib
!ENDIF
# Set the jpeg library
!IFDEF OUTPUT_JPEG
JPEG_LIB=3D$(JPEG_DIR)/libjpeg.lib
!ENDIF
# Set the png support libaries
!IFDEF OUTPUT_PNG
PNG_LIB=3D$(PNG_DIR)/libpng.lib $(ZLIB_DIR)/zlib.lib
!ENDIF
# Set the FreeType library
!IFDEF ANNOTATION_FT
#FT_LIB=3D$(FT_DIR)/objs/freetype211.lib
FT_LIB=3D$(FT_DIR)/objs/libs/libfreetype.lib
!ENDIF
# GD include and library
GD_INC=3D -I$(GD_DIR)
GD_LIB=3D $(GD_DIR)/gd.lib \
$(JPEG_LIB) $(PNG_LIB) $(FT_LIB)
GD=3D $(OUTPUT_PNG) $(OUTPUT_JPEG) $(OUTPUT_WBMP) $(OUTPUT_GIF) =
$(ANNOTATION_FT)
# Tiff library on input
!IFDEF TIFF
#TIFF_INC=3D-I$c:/projects/mapserver-4.0/tiff-v3.6.0/libtiff
#TIFF_LIB=3Dc:/projects/mapserver-4.0/tiff-v3.6.0/libtiff/libtiff.lib
TIFF_INC=3D -I$(TIFF_DIR)
TIFF_LIB=3D $(TIFF_DIR)/libtiff.lib
!ENDIF
# JPEG library on input
!IFDEF JPEG
!ENDIF
# Setup GDAL includes and libraries
!IFDEF GDAL
GDAL_INC =3D -I$(GDAL_DIR)/gcore -I$(GDAL_DIR)/alg =
-I$(GDAL_DIR)/ogr/ogrsf_frmts -I$(GDAL_DIR)/ogr =
-I$(GDAL_DIR)/ogr/../port
GDAL_LIB =3D $(GDAL_DIR)/gdal_i.lib
!ENDIF
# Setup OGR includes and libraries
!IFDEF OGR
OGR_INC =3D -I$(GDAL_DIR)/ogr/ogrsf_frmts -I$(GDAL_DIR)/ogr =
OGR_LIB =3D $(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts.lib =
$(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts_sup.lib $(GDAL_DIR)/ogr/ogr.lib =
$(GDAL_DIR)/ogr/../port/cpl.lib
!ENDIF
# Setup ESRI SDE support.
!IFDEF SDE_OPT
SDE_INC=3D-I$(SDE_DIR)/include
SDE_LIB=3D$(SDE_DIR)/lib/sde80.lib $(SDE_DIR)/lib/sg80.lib =
$(SDE_DIR)/lib/pe80.lib
!ENDIF
#ECW support
!IFDEF ECW_DIR
ECW_LIB=3D$(ECW_DIR)\lib\NCSEcw.lib $(ECW_DIR)\lib\NCSEcwC.lib \
$(ECW_DIR)\lib\NCSUtil.lib
!ENDIF
#Xerces support
!IFDEF XERCES_DIR
XERCES_LIB=3D$(XERCES_DIR)/lib/xerces-c_1.lib
!ENDIF
# Setup REGEX object and includes
!IFNDEF PHP
REGEX_OBJ=3D$(REGEX_DIR)\regex.obj
REGEX_INC=3D-I$(REGEX_DIR)
!ELSE
REGEX_OBJ=3D$(PHP_DIR)\regex\regcomp.obj $(PHP_DIR)\regex\regerror.obj \
$(PHP_DIR)\regex\regexec.obj $(PHP_DIR)\regex\regfree.obj
REGEX_INC=3D-I$(PHP_DIR)/regex -DPHP_NO_ALIASES
!ENDIF
# REGEX needs some special flags... here they are for VC++ 6.0
REGEX_OPT=3D-DHAVE_STRING_H -DREGEX_MALLOC
# Setup Postgesql PostGIS includes and libs
# Note that the Postgresql includes are not used in the compilation of=20
# PHP/MapScript. The reason is that there is a name conflict between =
the=20
# regex/regex.h files used in PHP and Postgresql. This is not a real =
issue
# since they are two completely different interfaces. The issue arrises =
when
# the php_regex.h trys to include regex/regex.h and gets the wrong one =
from
# postgresql. Therefore we do not give it that opertunity by not =
providing the
# include path.
!IFDEF POSTGIS
!IFNDEF PHP_BUILD_CALL
#POSTGIS_INC=3D-I$(POSTGIS_DIR)/src/interfaces/libpq =
-I$(POSTGIS_DIR)/src/include
POSTGIS_INC=3D-I$(POSTGIS_DIR)/interfaces/libpq -I$(POSTGIS_DIR)/include
!ENDIF
#POSTGIS_LIB=3D$(POSTGIS_DIR)/src/interfaces/libpq/release/libpqdll.lib
POSTGIS_LIB=3D$(POSTGIS_DIR)/interfaces/libpq/libpqdll.lib
POSTGIS_OBJ=3Dmappostgis.obj
!ENDIF
# Setup FLASH includes and libs
!IFDEF MING
MING_INC=3D-I$(MING_DIR)/src -I$(MING_DIR)
MING_LIB=3D $(MING_DIR)/src/libming.lib
!ENDIF
# Setup PDF includes and libs
!IFDEF PDF
PDF_LIB=3D$(PDF_DIR)/pdflib/pdflib.lib
PDF_INC=3D-I$(PDF_DIR)/pdflib
!ENDIF
# Section V: UMN GIS System Support
# UofMN GIS/Image Processing Extension (very experimental)
#EGIS=3D-DUSE_EGIS
!IFDEF EGIS
ERR_DIR=3Dc:/my_path_to/errLog
ERR_OBJ=3D$(ERR_DIR)/errLog.o
ERR_INC=3D-I$(ERR_DIR)
ERR_LIB=3D-L$(ERR_DIR) -lerrLog
IMGGEN_DIR=3Dc:/my_path_to/imgSrc
IMGGEN_OBJ=3D$(IMGGEN_DIR)/imgLib.o
IMGGEN_INC=3D-I$(IMGGEN_DIR)
IMGGEN_LIB=3D-L$(IMGGEN_DIR) -limgGEN
!ENDIF
LIBS=3D$(MS_LIB) $(GD_LIB) $(TIFF_LIB) $(JPEG_LIB) \
$(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
$(CURL_LIB) $(MING_LIB) $(PDF_LIB) \
$(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
$(XERCES_LIB) $(ECW_LIB)
INCLUDES=3D$(GD_INC) $(TIFF_INC) $(JPEG_INC) \
$(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
$(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
$(IMGGEN_INC) $(ERR_INC)
MS_CFLAGS=3D$(INCLUDES) $(REGEX_OPT) $(STRINGS) $(POSTGIS) \
$(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) \
$(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA) $(GDAL) \
-DFEATURE_INFO_HTML $(WFS) $(WFSCLIENT) $(PDF) $(EGIS) \
$(USE_GD_ANTIALIAS)
------=_NextPart_000_0037_01C3C087.14F081D0--
