[Mapserver-users] compiling mapserver 4.0.1 with SDE81 under
redhat 9: undefined reference to `__ctype_b'
Oliver Wesp
wesp at gdv.com
Mon Dec 15 05:02:28 EST 2003
Try to add the Option -lrt to SDE_LIB in your Makefile.
Rainer Spittel wrote:
> Hi,
> today is the day of the big update and I have my first problem...
> I want to use the Mapserver V4.0.1 on a RedHat 9.0 Server with SDE
> support (Version 8.1).
> I followed the instruction of the "RedHat9AndMapserver40" of the
> Wiki and everything is fine. After that, I've added postgis support and
> everything is fine.
> Now I want to add the SDE Support, installed the SDE Client
> libraries for RedHat with 'install -load' and setup the configuration
> for the mapserver like this:
> ./configure --without-tiff --without-eppl --with-threads --with-proj
> --with-gda\
> l=/usr/local/bin/gdal-config --with-ogr --with-php=../php-4.3.3
> --with-gd=/usr/\
> local --with-freetype=/usr/bin --with-pdf --without-ming
> --with-wmsclient --w\
> ith-wfs --with-wfsclient --with-sde=/usr/local/sdeexe81/
> --with-sde-version=81
> Now I receive following error message when I am compiling the mapserver:
> -I/usr/local/include -I/usr/local/include -I/usr/local/include
> mappdf.c -o mappdf.o
> mappdf.c: In function `msSaveImagePDF':
> mappdf.c:1167: warning: unused variable `out'
> mappdf.c: In function `msDrawTextPDF':
> mappdf.c:1300: warning: assignment makes integer from pointer without a
> cast
> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_PROJ -DUSE_PROJ_API_H
> -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR -DUSE_WFS_LYR -DUSE_JPEG
> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_PDF -DUSE_SDE
> -DUSE_OGR -DUSE_GDAL -DUSE_THREAD -I/usr/local/include
> -I/usr/local/sdeexe81//include -I/usr/local/include
> -I/usr/local/include -I/usr/local/include mapjoin.c -o mapjoin.o
> -I/usr/local/include -I/usr/local/include mapgraticule.c -o
> mapgraticule.o
> -I/usr/local/include -I/usr/local/include mapcopy.c -o mapcopy.o
> ar rc libmap.a maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o
> mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o
> mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o
> maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o
> mappostgis.o mapmygis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o
> maporaclespatial.o mapgml.o mapprojhack.o mapthread.o mapdraw.o mapgd.o
> mapoutput.o mapgdal.o mapswf.o mapimagemap.o mapows.o mapwfs.o
> mapwfslayer.o mapcontext.o maphttp.o mapdrawgdal.o mappdf.o mapjoin.o
> mapgraticule.o mapcopy.o
> ranlib libmap.a
> -I/usr/local/include -I/usr/local/include shp2img.c -o shp2img.o
> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_PROJ -DUSE_PROJ_API_H
> -I/usr/local/include -I/usr/local/include shp2img.o -L. -lmap
> -L/usr/local/lib -lgd -ljpeg -lfreetype -lpng -lz -lpdf -ljpeg
> -lfreetype -lpng -lz -lproj -ljpeg -L/usr/local/sdeexe81//lib -lsde81
> -lpe81 -lsg81 -lpthread -ldl -L/usr/local/lib -lgdal.1.1
> -L/usr/local/lib -lcurl -L/usr/kerberos/lib -lz -lssl -lcrypto -ldl
> -lssl -lcrypto -lgssapi_krb5 -lkrb5 -lcom_err -lk5crypto -lresolv -ldl
> -lz -lz -lpthread -lm -lstdc++ -o shp2img
> /usr/local/sdeexe81//lib/libsde81.so: the use of `tempnam' is dangerous,
> better use `mkstemp'
> /usr/local/sdeexe81//lib/libsde81.so: undefined reference to `__ctype_b'
> `__ctype_toupper'
> `__ctype_tolower'
> collect2: ld returned 1 exit status
> make: *** [shp2img] Fehler 1
> [root at 192 mapserver-4.0.1]#
> Is there something missing in the ld.so.conf? That is the current
> configuration:
> /usr/kerberos/lib
> /usr/X11R6/lib
> /usr/lib/qt-3.1/lib
> /usr/lib/sane
> /usr/local/lib
> /usr/local/pgsql/lib
> /usr/local/sdeexe81/lib/
> Does anyone have an idea? Merry x-mas and hope to hear from you... ;-)
> Ciao
> Rainer
> Dipl. Inf. Rainer Spittel
> TZI - Center for Computing Technologies
> Intelligent Systems
> University of Bremen
> Universitaetsallee 21-23, D-28359 Bremen, GERMANY
> Tel: 0421/218-7091 Fax: 0421/218-7196
> E-Mail: mailto:rasp at tzi.de
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dipl.-Geogr. Oliver Wesp
Gesellschaft fuer geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
