[Mapserver-users] Re: compiling mapserver 4.0 with gdal support on VC7
Swaminathan, Gayathri
gayathri at ou.edu
Mon Dec 15 09:59:49 EST 2003
Hello:
Just checking on a few things...
Do you need GDAL?
What all other options do you have going into your mapserver compile?
1) Did you compile and install GDAL before mapserver compile?
2) Was the gdal build sucessful?
3) VC7 acts kinda weird with GDAL nmake.opt...Guess it is a configuration
issue.,because the nmake.opt out there was generated using VC++6.0. Can you
try doing a workspace for GDAL and doing a workspace for mapserver and see
what happens?
If you just wanna save time and need a compiled gdal let me know..will send
ya one :) Cheers
-----Original Message-----
From: Ballini Yvain [mailto:Ballini.Yvain at seat.it]
Sent: Monday, December 15, 2003 8:55 AM
To: gayathri at ou.edu
Subject: compiling mapserver 4.0 with gdal support on VC7
Hi Gayathri
I'm trying to recompile mapserver 4.0 with OGR support (on Windows XP with
VC7).
Without the gdal support, it's everything ok but adding the gdal support
introduces a lot of problem during the recompilation of mapserver.
When I run the makefile.vc of mapserver, it gives me the following errors
for gdal 1.1.9:
cpl.lib(cpl_error.obj) : error LNK2019: unresolved external symbol
__imp___vsnpr intf referenced in function _CPLDebug
cpl.lib(cpl_string.obj) : error LNK2019: unresolved external symbol
__imp___vsnp rintf referenced in function _CSLSave
cpl.lib(cpl_vsisimple.obj) : error LNK2019: unresolved external symbol
__imp__fp uts referenced in function _VSIFPuts
__imp__mk dir referenced in function _VSIMkdir
OLDNAMES.lib(mkdir.obi) : error LNK2001: unresolved external symbol
__imp__mkdir
__imp__rm dir referenced in function _VSIRmdir
OLDNAMES.lib(rmdir.obi) : error LNK2001: unresolved external symbol
__imp__rmdir
__imp__strer ror referenced in function _CSLSave
__imp___errn o referenced in function _CSLSave
cpl.lib(cpl_dir.obj) : error LNK2019: unresolved external symbol
__imp___findclo se referenced in function _CPLReadDir
__imp___findnex t referenced in function _CPLReadDir
__imp___findfir st referenced in function _CPLReadDir
__imp___mkdi r
__imp___rmdi r mapserv.exe : fatal error LNK1120: 11 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
I think I've got a conflict problem between run-time C libraries (libc.lib,
libcmt.lib, MSVCRT.lib).
Do you know about another version of gdal which hasn't this problem, or
could you explain me please which runtime libary must be use fo all support?
I've added you the building files that I'm using for mapserver.
Thank you very much.
Yvain Ballini.
