[Mapserver-users] Re: Question about MapInfo.
Daniel Morissette
morissette at dmsolutions.ca
Mon Dec 15 11:06:36 EST 2003
Denis Louvegnies wrote:
> According to phpInfo the input=OGR is included. So I guest I should be able
> to open a Tab file.
> However even if I can open the demo file europe.map I got the following
> error when opening a tab file :
> Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named 'test'.
> in c:\program files\easyphp1-7\www\mapserver\tutorial\example_mi.php on line
> 10
> Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR connection
> `C:\tmp\ms_tmp\mapinfo\test.TAB'. File not found or unsupported format. in
> c:\program files\easyphp1-7\www\mapserver\tutorial\example_mi.php on line 10
> The TAB file is very basic, just one layer. If I run the ogrinfo tool :
> C:\tmp\ms_tmp\mapinfo>ogrinfo test.tab
> Had to open data source read-only.
> INFO: Open of `test.tab'
> using driver `MapInfo File' successful.
> 1: test (Polygon)
That's definitely very odd. Are you sure that the file is valid? Does
the following command work? It should dump the coordinates/attributes of
all the features in the file:
ogrinfo test.tab test
> LAYER
> NAME "test"
> TYPE POLYGON
> CONNECTIONTYPE OGR
> CONNECTION "C:\tmp\ms_tmp\mapinfo\test.TAB"
> STATUS ON
> CLASS
> END
> END
Try using the following connection strings, just in case:
CONNECTION "C:/tmp/ms_tmp/mapinfo/test.tab"
or
CONNECTION "/tmp/ms_tmp/mapinfo/test.tab"
Another thing you could try would be to load and draw the mapfile using
the mapserver/mapscript/php3/examples/the test_draw_map.phtml test
script that comes with the MapServer source.
If none of the above works then you might have to file a bug with a copy
of your mapfile and TAB data file to reproduce this with the
test_draw_map.phtml.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
