[Mapserver-users] HELP
Hugo Nathaniel Rodrigues
hugo at pbh.gov.br
Mon Dec 15 12:34:53 EST 2003
i just tested this, and i have org.:
MapServer version 4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
but still cant work my tab file, maybe is any wrong configuration in my map
file?
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
Sent: Saturday, December 13, 2003 10:17 AM
Subject: RE : [Mapserver-users] HELP
> Hi Hugo,
> you perhaps have to look if your mapserver configuration enables OGR
connexions for input.
> If you work with gmap and phpmapscript, you can view your config like
this:
> Make a new .php file and write:
> <?php
> dl( "php_mapscript.dll );
> phpinfo();
> Launch it, make sure that your php_mapscript is load.
> There is a section called MAPSCRIPT which descripe the current library
compiled with mapserver. that looks like:
> INPUT=OGR
> Cheers
> -------- Message d'origine--------
> De: Hugo Nathaniel Rodrigues [mailto:hugo at pbh.gov.br]
> Date: ven. 12.12.2003 17:57
> Ã: mapserver-users at lists.gis.umn.edu
> Cc:
> Objet: [Mapserver-users] HELP
> i just start to work with mapserver, and all looks to work well (with gmap
example), now im trying to work with one mapinfo file, but i receive this
error:
> msOGRFileOpen(): Open failed for OGR connection `distrito.tab'. File not
found or unsupported format. in
> in my map file i use this:
> LAYER
> NAME "Belo Horizonte"
> TYPE LINE
> CONNECTIONTYPE OGR
> CONNECTION "distrito.tab"
> STATUS ON
> END # layer
> my tab file i can open in mapinfo normal, is anything wrong with my layer?
maybe the mapinfo file is not supported?
> thanks for the future help
> sorry my bad english
> cheers
> Hugo Rodrigues
> Analista/Consultor
> SSSS - Prodabel
