[Mapserver-users] PHP MapScript and MapInfo files error
Hugo Nathaniel Rodrigues
hugo at pbh.gov.br
Mon Dec 15 12:36:30 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0048_01C3C321.36442AC0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
denis, can you send me that example .tab file so i can test here, im =
having the same problem of you (i think), im trying to use mapinfo files =
in php_mapscript and no luck.
cheers
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----=20
To: mapserver-users at lists.gis.umn.edu=20
Sent: Friday, December 12, 2003 8:09 PM
Subject: [Mapserver-users] PHP MapScript and MapInfo files error
Hi there,
I am just starting to use MapServer. I have propertly configured =
php_mapscript_41 and run the europe exemple. Great step!!
I am now trying to open a MapInfo file and I got the following error:=20
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named =
'test'. in c:\program =
files\easyphp1-7\www\mapserver\tutorial\example_mi.php on line 10
Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR =
connection `C:\tmp\ms_tmp\mapinfo\test.TAB'. File not found or =
unsupported format. in c:\program =
The TAB file is very basic, just one layer. If I run the ogrinfo tool =
C:\tmp\ms_tmp\mapinfo>ogrinfo test.tab
Had to open data source read-only.
INFO: Open of `test.tab'
using driver `MapInfo File' successful.
1: test (Polygon)
And the map file is :
NAME FIRSTMAP
SIZE 400 400
STATUS ON
SYMBOLSET "C:\tmp\ms_tmp\font\symbols_mapinfo.sym"
EXTENT -5696501 1923039 5696501 11022882
UNITS METERS
WEB
IMAGEPATH "/tmp/ms_tmp/"=20
IMAGEURL "/ms_tmp/"
END
LAYER
NAME "test"
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "C:\tmp\ms_tmp\mapinfo\test.TAB"
STATUS ON
=20
CLASS
END
END
END
Any clue ?
Thank you very much for your help !!
Denis
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>denis, can you send me that example =
.tab file so i=20
can test here, im having the same problem of you (i think), im trying to =
use=20
mapinfo files in php_mapscript and no luck.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>cheers</FONT></DIV>
<DIV>Hugo Rodrigues<BR>Analista/Consultor<BR>SSSS - Prodabel</DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A title=3Ddenis at louvegnies.com =
href=3D"mailto:denis at louvegnies.com">Denis=20
Louvegnies</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
title=3Dmapserver-users at lists.gis.umn.edu=20
href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.g=
is.umn.edu</A>=20
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Friday, December 12, 2003 =
8:09=20
PM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> [Mapserver-users] PHP =
MapScript=20
and MapInfo files error</DIV>
<DIV><BR></DIV>
<DIV><FONT face=3DArial size=3D2>Hi there,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I am just starting to use MapServer. =
I have=20
propertly configured php_mapscript_41 and run the europe exemple. =
Great=20
step!!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I am now trying to open a =
MapInfo file=20
and I got the following error: </FONT></DIV>
<DIV><FONT face=3DArial size=3D2><FONT size=3D3><FONT=20
face=3D"Times New Roman"><STRONG>Warning</STRONG>: [MapServer Error]:=20
msDrawMap(): Failed to draw layer named 'test'. in <B>c:\program=20
files\easyphp1-7\www\mapserver\tutorial\example_mi.php</B> on line=20
<B>10</B><BR><BR><B>Warning</B>: [MapServer Error]: msOGRFileOpen(): =
Open=20
failed for OGR connection `C:\tmp\ms_tmp\mapinfo\test.TAB'. File not =
found or=20
unsupported format. in <B>c:\program=20
<B>10</B></FONT></FONT><BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The TAB file is very basic, just one =
layer. If I=20
run the ogrinfo tool :</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>C:\tmp\ms_tmp\mapinfo>ogrinfo =
test.tab<BR>Had=20
to open data source read-only.<BR>INFO: Open of `test.tab'<BR>using =
driver=20
`MapInfo File' successful.<BR>1: test (Polygon)<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>And the map file is :</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>NAME FIRSTMAP<BR>SIZE 400 =
400<BR>STATUS=20
ON</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>SYMBOLSET=20
"C:\tmp\ms_tmp\font\symbols_mapinfo.sym"<BR>EXTENT -5696501 1923039 =
5696501=20
11022882<BR>UNITS METERS</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2><BR>WEB<BR> IMAGEPATH =
"/tmp/ms_tmp/"=20
<BR> IMAGEURL "/ms_tmp/"<BR>END</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>LAYER<BR> NAME=20
"test"<BR> TYPE POLYGON<BR> =
CONNECTIONTYPE=20
OGR<BR> CONNECTION=20
"C:\tmp\ms_tmp\mapinfo\test.TAB"<BR> STATUS=20
ON<BR> <BR> =20
CLASS<BR> END<BR>END</FONT><FONT=20
face=3DArial size=3D2><BR>END</DIV></FONT>
<DIV><FONT face=3DArial size=3D2> </DIV>
<DIV><BR></DIV></FONT>
<DIV><FONT face=3DArial size=3D2>Any clue ?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thank you very much for your help =
!!</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2>Denis</DIV></BLOCKQUOTE></FONT></BODY></HTML>
------=_NextPart_000_0048_01C3C321.36442AC0--
