[Mapserver-users] Empty screen with .tab file?
Hugo Nathaniel Rodrigues
hugo at pbh.gov.br
Tue Dec 16 12:02:05 EST 2003
i found this, maybe help:
- Seamless layers will not work in "No Path" mode unless all layers are in
the same folder as the Seamless layer. MapServer will return:
"msOGRFileOpen(): OGR error. Open failed for OGR connection
`\MyPath\MySeamlessLayer.TAB'. File not found or unsupported format. "
Using "Full Path" mode to create your seamless layer will also not work
unless the drive mapping on your MapServer machine matches that of the
machine you have MapInfo on for the layers. If you have a centralized
geographic data store like I do, your only option may be to place all layers
into the same folder and create your Seamless layer. MapInfo
cheers
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
Sent: Tuesday, December 16, 2003 2:36 PM
Subject: Re: [Mapserver-users] Empty screen with .tab file?
> Hugo,
> I don't know if the problem is the version of that DLL. Let me know your
> result if you are testing another version.
> Thanks,
> Denis
> From: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
> To: "Denis Louvegnies" <denis at louvegnies.com>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, December 16, 2003 5:17 PM
> > yes, im using that php_mapscript (file
> > php_mapscript_4.1-php-4.3.2-Oct72003.zip), maybe is this? maybe i need
to
> > try other version? (wich this one i had too many problems with path
names,
> > but i solve it all using the complete DOS path).
> > cheers
> > Hugo Rodrigues
> > Analista/Consultor
> > SSSS - Prodabel
> > From: "Denis Louvegnies" <denis at louvegnies.com>
> > Sent: Tuesday, December 16, 2003 2:08 PM
> > > Hugo,
> > > I agree. We have the same conclusion. We have the same error... Are
you
> > > using php_mapscript41.dll?
> > > The ogrinfo.exe comes from openev_fw package. you should be able to
find
> > it
> > > in the mapserver download section.
> > > Sent: Tuesday, December 16, 2003 4:58 PM
> > > > i just tested one thing:
> > > > i commented the lines:
> > > > CONNECTIONTYPE OGR
> > > > CONNECTION "./distrito.tab"
> > > > and with that, i received a blank screen, now im sure (again) that
the
> > > > problem in anything with the ogr connection.
> > > > Hugo Rodrigues
> > > > Analista/Consultor
> > > > SSSS - Prodabel
> > > > Sent: Tuesday, December 16, 2003 1:36 PM
> > > > > one END is missing at the end of your bhdistritos.map file
> > > > > Denis
> > > > > Sent: Tuesday, December 16, 2003 4:11 PM
> > > > > > here are my mapinfo files.
> > > > > > i receive all warnings and fatal errors, and cant open it :
> > > > > > Warning: [MapServer Error]: msLoadMap(): in c:\arquivos de
> > > > > programas\apache
> > > > > > group\apache\htdocs\testes basicos\mapabasico.phtml on line 7
> > > > > > Warning: Failed to open map file /tmp/ms_tmp/bhdistritos.map in
> > > > > c:\arquivos
> > > > > > de programas\apache group\apache\htdocs\testes
> > > > on
> > > > > > line 7
> > > > > > Fatal error: Call to a member function on a non-object in
> > c:\arquivos
> > > de
> > > on
> > > > > line
> > > > > > 8
> > > > > > i tried all type of paths in my map (and in my tab) files, and
> > > nothing.
> > > > > > cheers
> > > > > > Hugo Rodrigues
> > > > > > Analista/Consultor
> > > > > > SSSS - Prodabel
> > > > > > Sent: Tuesday, December 16, 2003 11:33 AM
> > > > > > > Hugo,
> > > > > > > I can' t make it work. That's why you are testing if you
could.
> > > > > > > Could you please send me your tab file, the one that display a
> > white
> > > > > > screen
> > > > > > > so I can test it here I see what happen.
> > > > > > > Thanks,
> > > > > > > Denis
> > > > > > > Sent: Tuesday, December 16, 2003 2:28 PM
> > > > > > > > how you make it works? i mean, is the same thing of the last
> > file
> > > > you
> > > > > > send
> > > > > > > > me, and i still have this when i run:
> > > > > > > > Warning: [MapServer Error]: msDrawMap(): Failed to draw
layer
> > > named
> > > > > > > 'test'.
> > > > > > > > in c:\arquivos de programas\apache
> > > > > > > > group\apache\htdocs\maisumexemploforum\mapabasico.phtml on
> line
> > 8
> > > > > > > > Warning: [MapServer Error]: msOGRFileOpen(): Open failed for
> OGR
> > > > > > > connection
> > > > > > > > `./test.tab'. File not found or unsupported format. in
> > c:\arquivos
> > > > de
> > > > > > > > programas\apache
> > > > > > > on
> > > > > > > > line 8
> > > > c:\arquivos
> > > > > de
> > > > > > > > programas\apache
> > > > > > > on
> > > > > > > > line 9
> > > > > > > > (not the blank map, but the error messages).
> > > > > > > > Hugo Rodrigues
> > > > > > > > Analista/Consultor
> > > > > > > > SSSS - Prodabel
> > > > > > > > Sent: Tuesday, December 16, 2003 10:58 AM
> > > > > > > > > Hugo,
> > > > > > > > > Here is the file. Give it a go and let me know,
> > > > > > > > > Cheers,
> > > > > > > > > Denis
> > > > > > > > > To: "Chiang Zeliang" <chiang_8_3 at hotmail.com>
> > > > > > > > > Sent: Tuesday, December 16, 2003 1:49 PM
file?
> > > > > > > > > > please, send the contents of your .map file, because im
> > trying
> > > > to
> > > > > > open
> > > > > > > > one
> > > > > > > > > > .tab file myself and maybe your map file works for me
> > > > > > > > > > cheers
> > > > > > > > > > Hugo Rodrigues
> > > > > > > > > > Analista/Consultor
> > > > > > > > > > SSSS - Prodabel
> > > > > > > > > > From: "Chiang Zeliang" <chiang_8_3 at hotmail.com>
> > > > > > > > > > To: <Mapserver-users at lists.gis.umn.edu>
> > > > > > > > > > Sent: Tuesday, December 16, 2003 2:50 AM
> > > > > > > > > > Subject: [Mapserver-users] Empty screen with .tab file?
> > > > > > > > > > > Hi all,
> > > > > > > > > > > I seem to have problems in opening a certain .tab
file.
> > The
> > > > .tab
> > > > > > > file
> > > > > > > > is
> > > > > > > > > a
> > > > > > > > > > > map of roads with its name and reference. It shows an
> > empty
> > > > > screen
> > > > > > > > > > whenever
> > > > > > > > > > > I use mapserver to open it, is this suppose to happen?
> > Need
> > > > > help.
> > > > > > > > > Thanks.
> > > > > > > > > > > From,
> > > > > > > > > > > Zeliang
> > > > > _________________________________________________________________
> > > > > > > > > > > Are you in love? Find a date on MSN Personals
> > > > > > > http://match.msn.com.my/
> > > > > > > > > > > Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
