[Mapserver-users] WFS Server Configuration
Bart van den Eijnden
bartvde at xs4all.nl
Tue Dec 16 13:36:59 EST 2003
Hi Joost,
I think this is the string which will be used in the output as the
descriptor/title for the geometry column (i.e. GML geometric property).
This is because shapefiles along with many other datasets don't have a
specific name for the spatial column (as the geometry is present in the
shp file itself), unlike e.g. Oracle Spatial.
So if you don't set it, you get "MS_GEOMETRY" in your output, which can
also be seen in the output you posted.
If you want to overrule this, you have to set the
"wfs_geometry_element_name" metedata to something else. This will be
present in your output then.
Best regards,
Bart
On Tue, 16 Dec 2003 13:17:04 -0500, Van Ulden, Joost
<jvanulde at nrcan.gc.ca> wrote:
> Could someone please clarify what exactly the "wfs_geometry_element_name"
> metadata element is supposed to do? Where is "MS_GEOMETRY" set?
> For some reason I am getting nothing back from the server when I query
> all
> properties of all instances of a feature type. Any suggestions? I am
> using
> a shapefile.
> This is what the documentation states:
> Name of the element (i.e. attribute) to use for the geometry in GML
> output.
> If not set then "MS_GEOMETRY" will be used. The layer-level
> "wfs_geometry_element_name" takes precedence over this value.
> Here is the DescribeFeatureType results for my shapefile:
> <complexType name="amsco_Type">
> <complexContent>
> <extension base="gml:AbstractFeatureType">
> <sequence>
> <element name="MS_GEOMETRY"
> type="gml:PolygonPropertyType"
> nillable="false" />
> <element name="AREA" type="string" />
> <element name="PERIMETER" type="string" />
> <element name="AMSCO_" type="string" />
> <element name="AMSCO_ID" type="string" />
> <element name="ID" type="string" />
> <element name="SYMBOL" type="string" />
> <element name="LABEL" type="string" />
> <element name="R" type="string" />
> <element name="G" type="string" />
> <element name="B" type="string" />
> <element name="RGB" type="string" />
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> Cheers,
> Joost van Ulden
> Programmer/Analyst
> Natural Resources Canada / Ressources naturelles Canada
> Geological Survey of Canada / Commission geologique du Canada
> 101 - 605 Robson Street / 101 - 605 rue Robson
> Vancouver, B.C. / Vancouver (C.-B.)
> V6B 5J3
> Office/Bureau: 604.666.7525
> fax/telecopieur: 604.666.1124
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
