[Mapserver-users] ms_newprojectionObj - change from v3.6 to v4.0??
Daniel Morissette
morissette at dmsolutions.ca
Tue Dec 16 17:05:28 EST 2003
Debbie Pagurek wrote:
> * *Hi all,
> I am trying to get some code that worked with php_mapscript_36.so to
> work with php_mapscript_40.so but am having problems.
> This worked before:
> $newproj=ms_newprojectionObj("proj=robin,lon_0=0,x_0=0,y_0=0");
> $latlon =
> ms_newprojectionObj("proj=longlat,ellps=GRS80,datum=NAD83,no_defs");
> $oldext= ms_newRectObj();
> $oldext->setextent($bounds[0],$bounds[1],$bounds[2],$bounds[3]);
> //the extent in latlong
> $newextproj = ms_newRectObj();
> $newextproj = $oldext->project($latlon,$newproj); //the extent in
> Robinson
The project() method has changed for all object types in version 4.0.
It operates directly on the object and returns MS_SUCCESS/MS_FAILURE.
<long_story>
This had to be changed because of a bug in the old project() method: it
used to modify the original object internally without updating the PHP
wrappers, plus the returned object used to invalidate the original
object so you could end up with crashes if the PHP variable referring to
the original object was deleted or modified.
</long_story>
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
