[Mapserver-users] time support
Daniel Morissette
morissette at dmsolutions.ca
Tue Dec 16 17:44:40 EST 2003
Steve Lime wrote:
> 2) As part of WCS support I'm adding the notion of a temporal index to
> MapServer. The idea being that you would use a tabular index (an xbase
> file) to organize data within a single layer temporally and then would
> specify which slice to use using some sort of a temporal id. That way
> you could serve 100's of images for a common geographic area using a
> single layer definition. There may well be benefits for vector data as
> well.
Steve,
How about allowing FILTER/FILTERITEM to be applied to data fields in the
TILEINDEX? You would end up combining the spatial and temporal index
into a single file. That would do the trick without any significant
change in MapServer.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
