[Mapserver-users] time support
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Tue Dec 16 20:30:29 EST 2003
Thanks for the info. We are looking forward to this functionality.
As for my specific problem, here's a use case.
Data: point data, with
X | Y | temperature | date
-75|45 |25 |25-Aug-2003
We have, on a daily basis, 160 years worth or records.
Scenario:
Show me the temperature on the day I was born through OGC:WMS.
So, we would make a GetMap request, with a filter for time, to show *only*
the data point for the given day, as per the attribute table.
..Tom
> -----Original Message-----
> From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
> Sent: Tuesday, December 16, 2003 4:29 PM
> To: Tom.Kralidis at ec.gc.ca; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] time support
> Hi Tom: I'm not aware of, but perhaps Daniel is, any plans for direct
> temporal support with WMS. There are however some peripheral
> activities
> that may be of interest.
> 1) The UMN (w/Frank) are working to develop OGR drivers for
> OPeNDAP/DODS servers. A GDAL driver has already been written
> by the DODS
> folks and integration tests with MapServer should be forthcoming.
> Because of the nature of the datasets distributed using these types of
> services the time element will become more important. I'm not
> sure what
> that means but we'll have a better idea in the near future.
> 2) As part of WCS support I'm adding the notion of a temporal index to
> MapServer. The idea being that you would use a tabular index (an xbase
> file) to organize data within a single layer temporally and then would
> specify which slice to use using some sort of a temporal id. That way
> you could serve 100's of images for a common geographic area using a
> single layer definition. There may well be benefits for vector data as
> well.
> 1) and 2) are in the works and should be completed this spring. There
> may certainly be other workarounds but we'd need more
> information about
> the problem you're trying to solve.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> 12/16/2003
> 11:41:26 AM >>>
> Hi,
> We have an activity which requires interfacing with a WMS supporting
> the
> TIME construct, as per ISO8601, for OGC:WMS communication with
> point-based
> temporal observation data.
> Does MapServer support this in its WMS face? If no, are there any
> plans to
> do so, and ETA? Are there any workaround / interim solutions to do
> this?
> Basically looking for a state of affairs w.r.t. this issue.
> Thanks
> ..Tom
> Tom Kralidis
> Systems Scientist
> Environment Canada
> Tel: +01-905-336-4409
> http://www.ec.gc.ca/cise/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
