[Mapserver-users] Empty screen with .TAB file
Denis Louvegnies
denis at louvegnies.com
Wed Dec 17 03:48:31 EST 2003
Hi Daniel,
I have tested using php_mapscript_35.dll.
It seems to be better because I don't get an error but now I get a Empty
screen....The generated image in empty...
Here is the map file:
NAME FIRSTMAP
SIZE 400 400
STATUS ON
#SYMBOLSET ../symbols/symbols.sym
SYMBOLSET "C:\tmp\ms_tmp\font\symbols_mapinfo.sym"
EXTENT -5696501 1923039 5696501 11022882
UNITS METERS
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "c:/tmp/ms_tmp/"
LOG "/tmp/gmap.log"
END
LAYER
NAME test
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CONNECTION ./test.TAB
CLASS
END
END
END
Any idea?
Many thanks,
Denis
----- Original Message -----
From: "Daniel Morissette" <morissette at dmsolutions.ca>
To: "Denis Louvegnies" <denis at louvegnies.com>
Cc: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>;
<mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, December 16, 2003 11:53 PM
Subject: Re: [Mapserver-users] Empty screen with .tab file?
> Denis Louvegnies wrote:
> > Hi Daniel,
> > Hugo and I have the same problem.
> > For me even with the absolute path it still doesn't work.
> > I wounder if any one could open a MapInfo file with
php_mapscript41.dll....
> Unfortunately I'm not setup to test on Windows so I can't help. Perhaps
> you can file a bug with all the details and your data file and if/when
> another developer on Windows has time to test this then they'll get back
> to you.
> BTW, did you try loading the same file with another DLL for version 4.0
> or 3.6?
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
