[Mapserver-users] Error: Oracle Connection String wrong?
Michael Schulz
mschulz at webgis.de
Wed Dec 17 10:41:55 EST 2003
did you try encapsulating the connection string in quotes? I can confirm
that you have to use CONNECTION "scott/tiger at db_sid" and CONNECTIONTYPE
oraclespatial.
This worked for me on with mapserver 4, win2000 and Oracle 8.1.7.
I experienced another error with an oracle 9.2 client, in that the
syntax of the db_sid has changed (or more specific when creating the
listener the name of the client was added automatically). Can someone
confirm this?
HTH, Michael
thelen at ccgis.de schrieb:
> Hi,
> We try to connect to a Oracle Spatial 9.2010 with Win32 MapServer 4. But
> we get the following error, passing the capabilites-request
> http://Server-URL/scripts/mapserv.exe?map=d:/mapserver/oracle.map&request=capabilities&wmtver=1.0.0:
> loadLayer(): Unknown identifier. Parsing error near (@):(line 53)
> The according line 53 in the map-file is
> CONNECTION user/pass at db
> That is nearly (user/pass[@]) what I copied from the MapServer documentation.
> Connecting via sql+ (oracle client) with "user/pass at db" is running properly.
> Up to now I could not find any example connection string on the internet
> (google, user list), but I will continue to search. As this is a quite
> urgent matter, I additionally post this e-mail!
> Thank you very much for any help!!
> Benjamin Thelen
> CCGIS GbR - Bonn
> http://www.ccgis.de
> Siemensstraße 8
> 53121 Bonn
> Germany
> Tel: ++49 (0) 228 90826 15
> Fax: ++49 (0) 228 90826 11
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
