[Mapserver-users] Java Mapscript example
Eduardo Spremolla
edspremolla at Antel.com.uy
Thu Dec 18 08:31:52 EST 2003
Hi every budy.
I compiled java mapscript successfully in a RH9 box with j2sdk1.4.1_02
Then I put libmapscript.so in /usr/local/lib, run ldconfig and test this
code:
import java.io.*;
import edu.umn.gis.mapscript.*;
public class Test {
public static void main(String[] args) throws IOException {
mapObj mapa;
imageObj imagen;
mapa=new mapObj("uru2.map");
imagen=mapa.draw();
imagen.save("uruguay_java.png");
but got:
[lalo at fly mvd]$ java -cp .:mapscript.jar Test
Exception in thread "main" java.lang.UnsatisfiedLinkError: new_mapObj
at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:296)
at Test.main(Test.java:10)
What's wrong?
Thanks in advance
Eduardo Spremolla <edspremolla at antel.com.uy>
Antel I+D
