[Mapserver-users] ArcView created layer not working in mapscript
Stephen Clark
stephen.clark at focus.ca
Thu Dec 18 11:26:33 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_09EE_01C3C540.A5505530
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Try this:
LAYER
NAME proposed_point
STATUS OFF
DATA "d:/folder/to/point_symbol/point"
TYPE POINT
LABELITEM "DESCRIPT"
CLASS
NAME 'Name' # the field in the DBF file to use to display as a =
label
COLOR 0 255 0
SYMBOL 'circle'
SIZE 10
LABEL
MINFEATURESIZE 100
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 255 0 0
END
END
=20
METADATA
WMS_TITLE "Point Labelled"
WMS_ABSTRACT "N/A "
#WMS_SRS "EPSG:26910"
END
END=20
----- Original Message -----=20
To: mapserver-users at lists.gis.umn.edu=20
Sent: Thursday, December 18, 2003 2:46 AM
Subject: [Mapserver-users] ArcView created layer not working in =
mapscript
Hello,
I am trying to make my own tiny, amatuer layer in ArcView 3.x and =
display it in mapscript but I am failing, I will be very glad if anyone =
can help...
This alyer of mine is just a single point at a certain coordinate, =
with a single label. I had learned how to make point layers from this =
list before but when it comes to adding label, I am stuck.
What I do in ArcView 3.x is:
1. Export data into a textfile
2. Choose Table->Add and select your Textfile
3. Choose View->Add Event Theme and select txt-table, the X- and=20
the Y-field.
4. Choose Theme->Convert to shapefile
My text file is:
"X","Y","NAME"
29.0708,40.9678,HELLO
So it is supposed to print thi point at the X and Y and also label it =
with HELLO
The shapefile I create works in Arcview itself but not under =
php/mapscript with this layer definition in the mapfile:
LAYER
NAME mylayer
TYPE point
STATUS ON
DATA mylayer
LABELCACHE ON
LABELITEM 'NAME'
CLASS
NAME 'NAME'
SYMBOL 'circle'
SIZE 5
COLOR 64 0 64
LABEL
TYPE truetype
# FORCE true
FONT arial
COLOR 64 0 64
ANGLE AUTO
POSITION AUTO
MINSIZE 2
SIZE 6
END
END
END
It gives an error about the NAME column.=20
Any ideas on creating a simple, labelled point layer?
Have a nice day.
Murat Isik
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Try this:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>LAYER<BR> NAME =
proposed_point<BR> =20
STATUS OFF<BR> DATA "d:/folder/to/point_symbol/point"<BR> =
TYPE=20
POINT<BR> LABELITEM "DESCRIPT"<BR> =
CLASS<BR> NAME=20
'Name' # the field in the DBF file to use to =
display as a=20
label<BR> COLOR 0 255 0<BR> SYMBOL=20
'circle'<BR> SIZE 10<BR> =20
LABEL<BR> MINFEATURESIZE=20
100<BR> MINDISTANCE=20
150<BR> POSITION=20
CC<BR> SIZE =
TINY<BR> =20
COLOR 255 0 0<BR> END<BR> =
END<BR> =20
<BR> METADATA<BR> WMS_TITLE "Point=20
Labelled"<BR> WMS_ABSTRACT "N/A =
"<BR> =20
#WMS_SRS "EPSG:26910"<BR> END<BR>END <BR></FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A title=3Dmuratisik at megatek.com.tr =
href=3D"mailto:muratisik at megatek.com.tr">Murat=20
Isik</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
title=3Dmapserver-users at lists.gis.umn.edu=20
href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.g=
is.umn.edu</A>=20
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Thursday, December 18, =
2003 2:46=20
AM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> [Mapserver-users] =
ArcView=20
created layer not working in mapscript</DIV>
<DIV><BR></DIV>
<DIV><FONT face=3DArial size=3D2>Hello,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I am trying to make my own tiny, =
amatuer layer in=20
ArcView 3.x and display it in mapscript but I am failing, I will be =
very glad=20
if anyone can help...</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>This alyer of mine is just a single =
point at a=20
certain coordinate, with a single label. I had learned how to make =
point=20
layers from this list before but when it comes to adding label, I am=20
stuck.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>What I do in ArcView 3.x =
is:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>1. Export data into a textfile<BR>2. =
Choose=20
Table->Add and select your Textfile<BR>3. Choose View->Add Event =
Theme=20
and select txt-table, the X- and <BR>the Y-field.<BR>4. Choose=20
Theme->Convert to shapefile</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>My text file is:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial=20
size=3D2>"X","Y","NAME"<BR>29.0708,40.9678,HELLO</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>So it is supposed to print thi point =
at the X and=20
Y and also label it with HELLO</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>The shapefile I create works in =
Arcview itself=20
but not under php/mapscript with this layer definition in the=20
mapfile:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>LAYER<BR> =
NAME mylayer<BR> TYPE=20
point<BR> STATUS ON<BR> DATA mylayer<BR> LABELCACHE=20
ON<BR> LABELITEM 'NAME'<BR> CLASS<BR> NAME=20
'NAME'<BR> SYMBOL 'circle'<BR> SIZE =
5<BR> =20
COLOR 64 0 64<BR> =
LABEL<BR> =20
TYPE truetype<BR># FORCE=20
true<BR> FONT=20
arial<BR> COLOR 64 0=20
64<BR> ANGLE=20
AUTO<BR> POSITION=20
AUTO<BR> MINSIZE=20
2<BR> SIZE 6<BR> =
END<BR> =20
END<BR>END<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>It gives an error about the NAME =
column.=20
</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Any ideas on creating a simple, =
labelled point=20
layer?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Have a nice day.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Murat =
Isik</FONT></DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_09EE_01C3C540.A5505530--
