[Mapserver-users] i found it!!!! i found it!!!!!!
Hugo Nathaniel Rodrigues
hugo at pbh.gov.br
Thu Dec 18 10:58:49 EST 2003
denis
take a look in the messages from the forum, i just sended a message to you
with this information and your files back.
cheers
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
Sent: Thursday, December 18, 2003 1:45 PM
Subject: Re: [Mapserver-users] i found it!!!! i found it!!!!!!
> Hello Hugo,
> I am just back from a two days meeting and according to your message you
> have fix the pb for viewing mapInfo file.
> Could you please sumaries in a few points what to do to fix the problem, I
> will be very gratefull !!
> Thank you very much,
> Denis
> From: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
> To: "Daniel Morissette" <morissette at dmsolutions.ca>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Thursday, December 18, 2003 4:24 PM
> > yes, i did that, and worked, im in the heaven now....
> > really thanks again Daniel!!!!
> > cheers
> > Hugo Rodrigues
> > Analista/Consultor
> > SSSS - Prodabel
> > From: "Daniel Morissette" <morissette at dmsolutions.ca>
> > Sent: Wednesday, December 17, 2003 9:45 PM
> > > Hugo Nathaniel Rodrigues wrote:
> > > > now, i only need to see this (i think my last question):
> > > > with ogrinfo i found this information:
> > > > INFO: Open of `distrito.tab'
> > > > using driver `MapInfo File' successful.
> > > > Layer name: distrito
> > > > Geometry: Polygon
> > > > Feature Count: 9
> > > > Extent: (598047.223047, 781652.733880) - (619791.428883,
> 812944.406142)
> > > > with that, i know my type (polygon), my connection (ogr), my unit
> > > > (meters), but, i dont know what i need to put in "EXTENT", can
anyone
> > > > help me?
> > > The syntax of the EXTENT directive is:
> > > EXTENT [minx] [miny] [maxx] [maxy]
> > > So based on the OGRINFO output above, you should use:
> > > EXTENT 598047.223047 781652.733880 619791.428883 812944.406142
> > > Daniel
> > > Daniel Morissette morissette at dmsolutions.ca
> > > DM Solutions Group http://www.dmsolutions.ca/
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
