Fw: [Mapserver-users] ArcView created layer not working in mapscript
Stephen Clark
stephen.clark at focus.ca
Thu Dec 18 14:51:42 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0015_01C3C55D.4DAFC0A0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
----- Original Message -----=20
To: Stephen Clark=20
Sent: Thursday, December 18, 2003 10:52 AM
Subject: Re: [Mapserver-users] ArcView created layer not working in =
mapscript
Hi:
Just try to keep names in double quotes
I mean LABELITEM 'NAME' has to be LABELITEM "NAME"
and CLASS
NAME 'NAME' has to be NAME "NAME"
Also check that in the DBF the column names are tiped in the same way =
you do in the map file.
I give you a part of the code who works ok for me.
Its a bit longer , I have classified the points by the population so 1 =
means capitols
2 Deparment Headers, 3 Towns, and so on
I you pay attention LABELITEM is Doblequoted and write exactly like the =
way ArcView shows it in the Table.--->Properties
Good Luck
JC.
#***** LAYER DE PUNTOS DE: Localidades, Cabeceras de Departamento y =
Capitales de Provincia *****
LAYER=20
NAME loc42
TYPE POINT
DATA loc42
STATUS OFF
LABELITEM "nomloc"
CLASSITEM 'Cabe'
CLASS
NAME "Capital de Provincia"
EXPRESSION /1/
COLOR 165 065 065
MAXSCALE 15000000=20
SYMBOL 'circle'
SIZE 9
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 0
POSITION auto
END
TEMPLATE "loc42.html"
END
CLASS
NAME "Cabeceras de Departamento"
EXPRESSION /5/
COLOR 065 165 065
MAXSCALE 5000000
SYMBOL 'circle'
SIZE 7
LABEL
TYPE BITMAP
SIZE tiny
COLOR 50 150 50
POSITION auto
WRAP " "
FORCE false
BUFFER 2
OFFSET -2 1
END
END
CLASS
NAME "Localidades"
EXPRESSION /0/
COLOR 065 065 165
MAXSCALE 900000
SYMBOL 'circle'
SIZE 5
LABEL
TYPE BITMAP
SIZE tiny
COLOR 50 50 250
POSITION UC
WRAP " "
FORCE false
BUFFER 2
OFFSET -2 1
END
END
HEADER "loc42_header.html"
FOOTER "loc42_footer.html"
TOLERANCE 5
METADATA
WMS_TITLE "Localidades"
WMS_ABSTRACT "Localidades de la Provincia de La Pampa."
WMS_SRS "EPSG:22193"
END
END
To: Murat Isik ; mapserver-users at lists.gis.umn.edu=20
Sent: Thursday, December 18, 2003 1:26 PM
mapscript
Try this:
LAYER
NAME proposed_point
STATUS OFF
DATA "d:/folder/to/point_symbol/point"
TYPE POINT
LABELITEM "DESCRIPT"
CLASS
NAME 'Name' # the field in the DBF file to use to display as a =
label
COLOR 0 255 0
SYMBOL 'circle'
SIZE 10
LABEL
MINFEATURESIZE 100
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 255 0 0
END
END
=20
METADATA
WMS_TITLE "Point Labelled"
WMS_ABSTRACT "N/A "
#WMS_SRS "EPSG:26910"
END
END=20
To: mapserver-users at lists.gis.umn.edu=20
Sent: Thursday, December 18, 2003 2:46 AM
Subject: [Mapserver-users] ArcView created layer not working in =
mapscript
Hello,
I am trying to make my own tiny, amatuer layer in ArcView 3.x and =
display it in mapscript but I am failing, I will be very glad if anyone =
can help...
This alyer of mine is just a single point at a certain coordinate, =
with a single label. I had learned how to make point layers from this =
list before but when it comes to adding label, I am stuck.
What I do in ArcView 3.x is:
1. Export data into a textfile
2. Choose Table->Add and select your Textfile
3. Choose View->Add Event Theme and select txt-table, the X- and=20
the Y-field.
4. Choose Theme->Convert to shapefile
My text file is:
"X","Y","NAME"
29.0708,40.9678,HELLO
So it is supposed to print thi point at the X and Y and also label =
it with HELLO
The shapefile I create works in Arcview itself but not under =
php/mapscript with this layer definition in the mapfile:
LAYER
NAME mylayer
TYPE point
STATUS ON
DATA mylayer
LABELCACHE ON
LABELITEM 'NAME'
CLASS
NAME 'NAME'
SYMBOL 'circle'
SIZE 5
COLOR 64 0 64
LABEL
TYPE truetype
# FORCE true
FONT arial
COLOR 64 0 64
ANGLE AUTO
POSITION AUTO
MINSIZE 2
SIZE 6
END
END
END
It gives an error about the NAME column.=20
Any ideas on creating a simple, labelled point layer?
Have a nice day.
Murat Isik
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV> </DIV>
<DIV style=3D"FONT: 10pt arial">----- Original Message -----=20
<DIV style=3D"BACKGROUND: #e4e4e4; font-color: black"><B>From:</B> <A=20
title=3Djfuch at indec.mecon.gov.ar =
href=3D"mailto:jfuch at indec.mecon.gov.ar">Juan=20
Carlos Fuchs</A> </DIV>
<DIV><B>To:</B> <A title=3Dstephen.clark at focus.ca=20
href=3D"mailto:stephen.clark at focus.ca">Stephen Clark</A> </DIV>
<DIV><B>Sent:</B> Thursday, December 18, 2003 10:52 AM</DIV>
<DIV><B>Subject:</B> Re: [Mapserver-users] ArcView created layer not =
working in=20
mapscript</DIV></DIV>
<DIV><BR></DIV>
<DIV><FONT size=3D2>Hi:</FONT></DIV>
<DIV><FONT size=3D2>Just try to keep names in double quotes</FONT></DIV>
<DIV><FONT size=3D2>I mean LABELITEM 'NAME' has to be LABELITEM=20
"NAME"</FONT></DIV>
<DIV><FONT size=3D2>and CLASS<BR> NAME 'NAME' has to =
be NAME=20
"NAME"<BR>Also check that in the DBF the column names are tiped in the =
same way=20
you do in the map file.</FONT></DIV>
<DIV><FONT size=3D2></FONT> </DIV>
<DIV><FONT size=3D2>I give you a part of the code who works ok for=20
me.</FONT></DIV>
<DIV><FONT size=3D2>Its a bit longer , I have classified the points by =
the=20
population so 1 means capitols</FONT></DIV>
<DIV><FONT size=3D2>2 Deparment Headers, 3 Towns, and so on</FONT></DIV>
<DIV><FONT size=3D2>I you pay attention LABELITEM is Doblequoted and =
write exactly=20
like the way ArcView shows it in the =
Table.--->Properties</FONT></DIV>
<DIV><FONT size=3D2>Good Luck</FONT></DIV>
<DIV><FONT size=3D2>JC.</FONT></DIV>
<DIV><FONT=20
size=3D2>#***************************************************************=
************<BR>#***** =20
LAYER DE PUNTOS DE: Localidades, Cabeceras de Departamento y Capitales =
de=20
Provincia =20
*****<BR>#***************************************************************=
************</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D2>LAYER <BR> NAME loc42<BR> TYPE =
POINT<BR> =20
DATA loc42<BR> STATUS OFF<BR> LABELITEM =
"nomloc"</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D2>CLASSITEM =
'Cabe'<BR>CLASS<BR> NAME=20
"Capital de Provincia"<BR> EXPRESSION=20
/1/<BR> COLOR 165 065 =
065<BR> =20
MAXSCALE 15000000 <BR> SYMBOL=20
'circle'<BR> SIZE 9</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D2> LABEL<BR> TYPE=20
BITMAP<BR> SIZE MEDIUM<BR> COLOR 0 0 =
0<BR> POSITION auto<BR> END</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D2> TEMPLATE =
"loc42.html"<BR> =20
END</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D2> CLASS<BR> NAME =
"Cabeceras=20
de Departamento"<BR> EXPRESSION=20
/5/<BR> COLOR 065 165 =
065<BR> =20
MAXSCALE 5000000<BR> SYMBOL=20
'circle'<BR> SIZE 7</FONT></DIV>
<DIV> </DIV>
BITMAP<BR> SIZE tiny<BR> COLOR 50 =
150=20
50<BR> POSITION auto<BR> WRAP "=20
"<BR> FORCE false<BR> BUFFER=20
2<BR> OFFSET -2 1<BR> END</FONT></DIV>
<DIV> </DIV>
END</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D2>CLASS<BR> NAME=20
"Localidades"<BR> EXPRESSION=20
/0/<BR> COLOR 065 065 =
165<BR> =20
MAXSCALE 900000<BR> SYMBOL=20
'circle'<BR> SIZE 5</FONT></DIV>
<DIV> </DIV>
BITMAP<BR> SIZE tiny<BR> COLOR 50 50 =
250<BR> POSITION UC<BR> WRAP "=20
<DIV> </DIV>
END</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D2> HEADER "loc42_header.html"<BR> FOOTER=20
"loc42_footer.html"</FONT></DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV><FONT size=3D2><BR> TOLERANCE 5</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D2> METADATA<BR> WMS_TITLE=20
"Localidades"<BR> WMS_ABSTRACT "Localidades de la =
Provincia de=20
La Pampa."<BR> WMS_SRS "EPSG:22193"<BR> =
END<BR>END</DIV>
<DIV><BR></DIV></FONT>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A title=3Dstephen.clark at focus.ca =
href=3D"mailto:stephen.clark at focus.ca">Stephen=20
Clark</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A =
title=3Dmuratisik at megatek.com.tr=20
href=3D"mailto:muratisik at megatek.com.tr">Murat Isik</A> ; <A=20
title=3Dmapserver-users at lists.gis.umn.edu=20
href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.g=
is.umn.edu</A>=20
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Thursday, December 18, =
2003 1:26=20
PM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> Re: [Mapserver-users] =
ArcView=20
created layer not working in mapscript</DIV>
<DIV><BR></DIV>
<DIV><FONT face=3DArial size=3D2>Try this:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>LAYER<BR> NAME =
proposed_point<BR> =20
STATUS OFF<BR> DATA "d:/folder/to/point_symbol/point"<BR> =
TYPE=20
POINT<BR> LABELITEM "DESCRIPT"<BR> =
CLASS<BR> =20
NAME 'Name' # the field in the DBF file to use to=20
display as a label<BR> COLOR 0 255=20
0<BR> SYMBOL 'circle'<BR> SIZE=20
10<BR> LABEL<BR> =20
MINFEATURESIZE 100<BR> MINDISTANCE=20
150<BR> POSITION=20
CC<BR> SIZE=20
TINY<BR> COLOR 255 0 =
0<BR> =20
END<BR> END<BR> <BR> =20
METADATA<BR> WMS_TITLE "Point=20
Labelled"<BR> WMS_ABSTRACT "N/A =
"<BR> =20
#WMS_SRS "EPSG:26910"<BR> END<BR>END <BR></FONT></DIV>
<DIV=20
<A title=3Dmuratisik at megatek.com.tr=20
href=3D"mailto:muratisik at megatek.com.tr">Murat Isik</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
is.umn.edu</A>=20
</DIV>
2003 2:46=20
AM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> [Mapserver-users] =
ArcView=20
<DIV><BR></DIV>
<DIV><FONT face=3DArial size=3D2>Hello,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I am trying to make my own tiny, =
amatuer layer=20
in ArcView 3.x and display it in mapscript but I am failing, I will =
be very=20
glad if anyone can help...</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>This alyer of mine is just a single =
point at a=20
certain coordinate, with a single label. I had learned how to make =
point=20
layers from this list before but when it comes to adding label, I am =
stuck.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>What I do in ArcView 3.x =
is:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>1. Export data into a =
textfile<BR>2. Choose=20
Table->Add and select your Textfile<BR>3. Choose View->Add =
Event Theme=20
and select txt-table, the X- and <BR>the Y-field.<BR>4. Choose=20
Theme->Convert to shapefile</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>My text file is:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial=20
size=3D2>"X","Y","NAME"<BR>29.0708,40.9678,HELLO</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>So it is supposed to print thi =
point at the X=20
and Y and also label it with HELLO</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>The shapefile I create works in =
Arcview itself=20
but not under php/mapscript with this layer definition in the=20
mapfile:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>LAYER<BR> =
NAME mylayer<BR> =20
TYPE point<BR> STATUS ON<BR> DATA mylayer<BR> =
LABELCACHE=20
ON<BR> LABELITEM 'NAME'<BR> CLASS<BR> NAME=20
'NAME'<BR> SYMBOL 'circle'<BR> SIZE=20
5<BR> COLOR 64 0 64<BR> =20
LABEL<BR> TYPE=20
truetype<BR># FORCE=20
true<BR> FONT=20
arial<BR> COLOR 64 0=20
64<BR> ANGLE=20
AUTO<BR> POSITION=20
AUTO<BR> MINSIZE=20
2<BR> SIZE 6<BR> =
END<BR> =20
END<BR>END<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>It gives an error about the NAME =
column.=20
</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Any ideas on creating a simple, =
labelled point=20
layer?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Have a nice day.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Murat=20
Isik</FONT></DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0015_01C3C55D.4DAFC0A0--
