[Mapserver-users] .tab files problems again
Hugo Nathaniel Rodrigues
hugo at pbh.gov.br
Fri Dec 19 08:58:16 EST 2003
but what is exact the problem? blank screen?
how start your map file? (extent, web paths, etc)
cheers
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: <hugo at pbh.gov.br>
Cc: <Mapserver-users at lists.gis.umn.edu>
Sent: Friday, December 19, 2003 2:59 AM
Subject: Re: [Mapserver-users] .tab files problems again
> Hi,
> I have a similar problem and i have checked my .tab file with ogrinfo. Can
> you help me and determine what type and coding should i use for this .tab
> file?
> thanks
> From,
> Zeliang
> This is what i've got using ogrinfo:
> Layer name: Msia_Mainroads
> Geometry: Line String
> Feature Count: 3662
> Extent: (-85297.812205, 102267.713704) - (2090681.069111, 829390.210029)
> Layer SRS WKT:
> PROJCS["unnamed",
> GEOGCS["unnamed",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563],
> TOWGS84[0,0,0,0,0,0,0]],
> PRIMEM["Greenwich",0]
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",105],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["Meter",1.0]]
> Rd_name: String (50.0)
> Rd_No: String (50.0)
> Type: String (50.0)
> This is the coding i am using for this layer:
> LAYER
> NAME 'Msia_Mainroads'
> TYPE line
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "C:\Inetpub\wwwroot\VesselTracking\Data\Msia_Mainroads.TAB"
> STYLEITEM "AUTO"
> MAXSCALE 5000000.0
> CLASS
> END
> PROJECTION
> "AUTO"
> END
> END # Layer
> >From: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
> >To: "Riccardo Stuper" <rik_stpr at yahoo.it>
> >CC: <mapserver-users at lists.gis.umn.edu>
> >Date: Thu, 18 Dec 2003 15:51:49 -0200
> >Riccardo,
> >i think i found your problem: you didnt create an alias, let me explain:
> >to use the folder
> > IMAGEPATH "../ms_tmp"
> > IMAGEURL "/maplab-2.1-RC1/ms_tmp"
> >in the WEB section of your MAP file, you need to have it in your
httpd.conf
> >of your apache configuration, like this:
> > Alias /gmap/ "C:/Arquivos de programas/Apache
> >Group/Apache/htdocs/gmap/"
> > Alias /ms_tmp/ "C:/tmp/ms_tmp/"
> >and you need to have this folders... in my case, i tried your map file,
and
> >get one little box with red X (like one no found jpg in the page), then,
i
> >tried the same map file using my configuration of WEB section:
> > IMAGEPATH "/tmp/ms_tmp/"
> > IMAGEURL "/ms_tmp/"
> >and then worked well (now i have that blue map), the other thing that you
> >need its a php file like the one im sending to you (now, if you can do it
> >without php file, i dont know, because i just started).
> >cheers
> >Hugo Rodrigues
> >Analista/Consultor
> >SSSS - Prodabel
> > From: Riccardo Stuper
> > To: Hugo Nathaniel Rodrigues
> > Sent: Thursday, December 18, 2003 2:54 PM
> > Hugo,
> > here are my files. There is only one layer, very simple. I add one of
> >the html file I've tried to use, just in case there would be something
> >horribly wrong in it...
> > Thank you very much for your help.
> > cheers
> > RS
> > Hugo Nathaniel Rodrigues <hugo at pbh.gov.br> wrote:
> > send me your files (mapserver .map and all the mapinfo files) i will
> >see if i can run here.
> > cheers
> > Hugo Rodrigues
> > Analista/Consultor
> > SSSS - Prodabel
> > Cc: mapserver-users at lists.gis.umn.edu
> > Sent: Thursday, December 18, 2003 8:26 AM
> > Hugo,
> > thanx for answer. I've tried ogrinfo, it tells "Open of
> >`Friuli.tab'... successful" then all the informations. (I notice I need
to
> >put the "ogrinfo.exe" in the same folder of the files to analyze).
> > I put the extent in my map file, nothing. White map, no ref, no
> >scale as always. Neither imagecolor helps.
> > Maybe it's something else w/ogr connection (but ogrinfo tells it's
> >ok), some dll missing, Apache configuration, I followed the instructions
> >and all seems ok, the demo was working.
> > I cannot understand why I could open the map w/MapLap-MapEdit tool
> >and no way else, but I cannot use always this...
> > I don't know what to do. Thx anyway.
> > cheers
> > R.S.
> > riccardo,
> > first of all, go to DOS prompt and type ogrinfo friuli.tab (if
you
> >dont have the ogrinfo file, download it in
> >ftp://ftp.remotesensing.org/pub/gdal/openev/ (you need to download any FW
> >or linux version, but not the win32 exe version, because the installation
> >dont have the ogrinfo file), then unzip it and take the ogrinfo file
(when
> >you run the ogrinfo file, this will show you some dll files that is not
in
> >your windows dll folder, you will found it in the zip file, and can put
it
> >in windows/system32, or system, depends of the version of your windows,
but
> >take care to not copy this if you have other version installed).
> > with the ogrinfo working, and the information you get
(ogrinfo -al
> >-ro friuli.tab), get the information of EXTENDED and put it in your map
> >file (take of the one you have).
> > maybe this works, if not, try to put imagecolor in your map file
> >start section (imagecolor 255 255 255).
> > i wish this can help you.
> > cheers
> > Hugo Rodrigues
> > Analista/Consultor
> > SSSS - Prodabel
> > Yahoo! Mail: 6MB di spazio gratuito, 30MB per i tuoi allegati,
> >l'antivirus, il filtro Anti-spam
> ><< mapabasico.zip >>
> _________________________________________________________________
> Using a handphone prepaid card? Reload your credit online!
> http://www.msn.com.my/reloadredir/default.asp
> Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
