[Mapserver-users] about shapefile
    Lowell Filak
    lfilak at medinaco.org
    Tue Dec 23 08:15:50 PST 2003
It's seems like there are several tools out there which already allow
for the direct manipulation of shapefiles at a more generic level than
delving into the actual shapefile structure.
Are you sure that your needs could not be met by one of the existing
applications/libraries, ie. MapScript?
Lowell
The following message was sent by Aga Shirazi <ashirazi at buffalo.edu> on
Tue, 23 Dec 2003 10:54:00 -0500.
> Hi,
> I wanted to learn how a shpefile is structured, created and compiled. I
> read the technical description from ESRI about Shapefiles, but I couldnt
> get much out of it as I lack a GIS programming background. For
instance: I
> have no idea what PolygonZ or M is, and why would I use it. I also
couldnt
> find in the Tech. paper how can I code and compile a shapefile?
> I would be greatly appreciative if someone could name some websites or
> books that could guide me.
> Thanks
> Aga Shirazi
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
