[Mapserver-users] Mulitiline string to Polygon
nida Khan
nida at webstar.co.uk
Thu Jan 2 05:41:18 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_012F_01C2B24B.7B9440C0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi list,
I have three table created from .NTF(boundary line) file provided by =
Ordinance Survery. using ogr2ogr.
One with geometry data, other two with features information. namely, =
BL2000_LINK,BL2000_POLY,BL2000_COLLECTION
I can create the map perfectly fine, main problem comes, when I want to =
display a label from those feature table.
As its a MultilineString geom, label comes on top of line, instead of =
middle of "formed polygon", which makes sense...
Is there anyway of controling the inside area of two lines???
I thought If I can create a polygon geometry instead of multilineString =
it can make my task easy!
Is there any way of doing it???
Has anyone ever worked on Boundary line data from Ordinance Survey =
before? If yes, how do you cope with these problems?
How do you inforce relational integrity b/w three tables?
Best Regards
Nida.
PS:my table structrue is like this.
test=3D# \d bl200_llnik
Column | Type | Modifiers=20
gid | integer |=20
line_id | integer |=20
geom_id | integer |=20
feat_code | character varying |=20
global_lin | integer |=20
tile_ref | character varying |=20
the_geom | geometry |=20
Check constraints: "$1" (srid(the_geom) =3D -1)
"$2" ((geometrytype(the_geom) =3D =
'MULTILINESTRING'::text) OR (the_geom IS NULL))
test=3D# \d bl2000_poly=20
=20
Column | Type | =
Modifiers =20
ogc_fid | integer | not null default =
nextval('"bl2000_poly_ogc_fid_seq"'::text)
wkb_geometry | geometry |=20
poly_id | numeric(6,0) |=20
global_seed_id | numeric(6,0) |=20
hectares | numeric(12,3) |=20
num_parts | numeric(4,0) |=20
dir | character varying |=20
geom_id_of_link | character varying |=20
ringstart | character varying |=20
tile_ref | character(10) |=20
Unique keys: bl2000_poly_ogc_fid_key
Check constraints: "$1" (srid(wkb_geometry) =3D 104306)
test=3D# \d bl2000_collection=20
=20
Column | Type | =
Modifiers =20
nextval('"bl2000_collection_ogc_fid_seq"'::text)
coll_id | numeric(6,0) |=20
poly_id | character varying |=20
admin_area_id | numeric(6,0) |=20
admin_name | character varying |=20
area_type | character(2) |=20
area_code | character(3) |=20
non_type_code | character(3) |=20
non_inland_area | numeric(12,3) |=20
coll_id_refs | character varying |=20
Unique keys: bl2000_collection_ogc_fid_key
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2600.0" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT size=3D2>Hi list,</FONT></DIV>
<DIV><FONT size=3D2></FONT> </DIV>
<DIV><FONT size=3D2>I have three table created from .NTF(boundary =
line) file=20
provided by Ordinance Survery. using ogr2ogr.</FONT></DIV>
<DIV><FONT size=3D2>One with geometry data, other two with features =
information.=20
namely, BL2000_LINK,BL2000_POLY,BL2000_COLLECTION</FONT></DIV>
<DIV><FONT size=3D2>I can create the map perfectly fine, main problem =
comes, when=20
I want to display a label from those feature table.</FONT></DIV>
<DIV><FONT size=3D2>As its a MultilineString geom, label comes on top of =
line,=20
instead of middle of "formed polygon", which makes sense...</FONT></DIV>
<DIV><FONT size=3D2>Is there anyway of controling the inside area of two =
lines???</FONT></DIV>
<DIV><FONT size=3D2>I thought If I can create a polygon geometry instead =
of=20
multilineString it can make my task easy!</FONT></DIV>
<DIV><FONT size=3D2>Is there any way of doing it???</FONT></DIV>
<DIV><FONT size=3D2>Has anyone ever worked on Boundary line data from =
Ordinance=20
Survey before? If yes, how do you cope with these =
problems?</FONT></DIV>
<DIV><FONT size=3D2>How do you inforce relational integrity b/w three=20
tables?</FONT></DIV>
<DIV><FONT size=3D2>Best Regards</FONT></DIV>
<DIV><FONT size=3D2>Nida.</FONT></DIV>
<DIV><FONT size=3D2>PS:my table structrue is like =
this.</FONT></DIV><FONT size=3D2>
<DIV><BR>test=3D# \d bl200_llnik</DIV>
<DIV> Column =
| =20
Type | Modifiers=20
<BR>------------+-------------------+-----------<BR> gid =
=20
| integer |=20
<BR> line_id |=20
integer |=20
<BR> geom_id |=20
integer |=20
<BR> feat_code | character varying | <BR> global_lin |=20
integer |=20
<BR> tile_ref | character varying |=20
<BR> the_geom |=20
geometry | =
<BR>Check=20
constraints: "$1" (srid(the_geom) =3D=20
-1)<BR> =
=20
"$2" ((geometrytype(the_geom) =3D 'MULTILINESTRING'::text) OR (the_geom =
IS=20
NULL))</DIV>
<DIV> </DIV>
<DIV>test=3D# \d=20
bl2000_poly <BR> &nbs=
p;  =
; </DIV>
<DIV> Column =20
| =20
Type =20
nbsp;=20
Modifiers &nbs=
p;  =
; =20
<BR>-----------------+-------------------+-------------------------------=
------------------------------<BR> ogc_fid &n=
bsp; =20
| integer | =
not null=20
default=20
nextval('"bl2000_poly_ogc_fid_seq"'::text)<BR> wkb_geometry &nb=
sp; =20
| geometry |=20
<BR> poly_id |=20
numeric(6,0) | =
<BR> global_seed_id |=20
numeric(6,0) |=20
<BR> hectares |=20
numeric(12,3) |=20
<BR> num_parts |=20
numeric(4,0) |=20
<BR> dir =
=20
| character varying | <BR> geom_id_of_link | character varying |=20
<BR> ringstart | character =
varying |=20
<BR> tile_ref |=20
character(10) | <BR>Unique keys:=20
bl2000_poly_ogc_fid_key<BR>Check constraints: "$1" (srid(wkb_geometry) =
=3D=20
104306)</DIV>
<DIV> </DIV>
<DIV>test=3D# \d bl2000_collection <BR> </DIV>
<DIV> Column =20
| =20
Type =20
nbsp; =20
Modifiers &nbs=
p;  =
; =20
------------------------------------<BR> ogc_fid &n=
bsp; =20
| integer | =
not null=20
default=20
nextval('"bl2000_collection_ogc_fid_seq"'::text)<BR> wkb_geometry&nb=
sp; =20
| geometry |=20
<BR> coll_id |=20
numeric(6,0) |=20
<BR> num_parts |=20
numeric(4,0) |=20
<BR> poly_id | =
character=20
varying | <BR> admin_area_id |=20
numeric(6,0) =20
| <BR> admin_name | character =
varying |=20
<BR> area_type |=20
character(2) |=20
<BR> area_code |=20
character(3) | =
<BR> non_type_code =20
| character(3) | <BR> non_inland_area =
|=20
numeric(12,3) | =
<BR> coll_id_refs =20
<BR> tile_ref |=20
bl2000_collection_ogc_fid_key<BR>Check constraints: "$1" =
(srid(wkb_geometry) =3D=20
104306)</FONT></DIV></BODY></HTML>
------=_NextPart_000_012F_01C2B24B.7B9440C0--
