[Mapserver-users] mapscript and XBase cause Out of memory error and/or premature end
of script headers error
Jonathan W. Lowe
jlowe at giswebsite.com
Thu Jan 2 19:34:07 EST 2003
List:
Perl mapscript in combination with the perl XBase and CGI modules works
very well in my Redhat 8 development environment, but when moving the
code to the production FreeBSD environment, the following problem
results:
A program containing the statements...
use mapscript;
use XBase;
...runs the mapscript portions correctly when just the "use XBase;" line
is commented out.
The same program runs the XBase portions correctly when just the "use
mapscript;" line is commented out.
The line causing problems when both modules are running contains the
following perl mapscript command:
my $img = $map->draw() or die('Unable to draw map');
The resulting line in the apache error_log reads:
Out of memory!
[Thu Jan 2 16:09:25 2003] [error] Premature end of script
headers...etc
The only posting referring to "Out of memory" in this context refers to
SWIG and is a couple of years old.
Any ideas for resolving this problem?
Regards,
Jonathan W. Lowe
