[Mapserver-users] making the demo work with non-gif GD libs
Lowell Filak
lfilak at medinaco.org
Mon Jan 6 09:27:28 EST 2003
You could try "convert" - part of the Imagemagick package.
HTH
Lowell F.
The following message was sent by richard hornsby <rhornsby at io.osuedc.org> on Mon, 6 Jan 2003 09:03:51 -0500 (EST).
> I think I'm running with GD libs somewhere around 1.8, but the point being
> that they don't support GIF rendering, because of the patent issues, etc.
> However, when running the mapserv demo, I wasn't getting errors
> specifically related to GD - instead I was getting things like:
> msLoadMap(): General error message. Undefined symbol "symbols/ctyhwy.gif"
> in class 0 of layer ctyrdln3_anno.
> The "symbol" exists in the directory that it should. The docs suggest to
> comment out large sections of your .map file. However, I converted the
> .gif symbols and 'reference.gif' to pngs, and changed the references in
> demo.map to png, it works happily.
> Slightly off-topic, for larger projects which need this kind of
> conversion, you can certainly use sed on the .map file, but does anyone
> know of tools to convert images between formats quickly (ala sox)?
> thanks
> -rj
> Information Center, n.:
> A room staffed by professional computer people whose job it is to
> tell you why you cannot have the information you require.
> rj hornsby . systems engineer . www.osuedc.org
> human and community resource development
> p 614 688 8761 . f 614 688 8762
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
