[Mapserver-users] about unicode to big5?
Mikeyahoo
mike_5102 at yahoo.com.tw
Tue Jan 7 11:56:39 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_000F_01C2B6B0.CD274F40
Content-Type: text/plain;
charset="big5"
Content-Transfer-Encoding: quoted-printable
Hello all,
I have PHP ver4.0.6 and MapServer version 3.5. and the dbms is =
postgresql7.1.3.I want to show the big5 on my map.My db had already =
converted the unicode to the big5,but the map on web still show the =
unicode.So I want to use php/mapscript to convert the word.following is =
the program that download on web:
<?php
Function U2Utf8($c){
If($c < 0x80) {
$str.=3D$c;
}ElseIf($c < 0x800) {
$str.=3D(0xC0 | $c>>6);
$str.=3D(0x80 | $c & 0x3F);
}ElseIf($c < 0x10000) {
$str.=3D(0xE0 | $c>>12);
$str.=3D(0x80 | $c>>6 & 0x3F);
}ElseIf($c < 0x200000) {
$str.=3D(0xF0 | $c>>18);
$str.=3D(0x80 | $c>>12 & 0x3F);
Return $str;
Function Big52Utf8($Big5){
//Modify By MingSen Zhao
If(!Trim($Big5)) Return $Big5;
$tmp=3DFile("./BIG5.TXT");
Foreach($tmp as $key =3D> $value)
$codetable[Hexdec(Substr($value,0,6))]=3DSubstr($value,7,6);
While($Big5){
If(Ord(Substr($Big5,0,1))>127){
$utf8=3DU2Utf8(Hexdec($codetable[Hexdec(Bin2hex(Substr($Big5,0,2)))]));
For($i=3D0;$i<Strlen($utf8);$i+=3D3)
$ret.=3DChr(Substr($utf8,$i,3));
$Big5=3DSubstr($Big5,2,Strlen($Big5));
}Else{
$ret.=3DSubstr($Big5,0,1);
$Big5=3DSubstr($Big5,1,Strlen($Big5));
Return $ret;
it need a file "big5.txt" that is a u8tob5 table.this program can be =
running correctly.but the word on map is still unreadable.It seems to =
transfer uncompletely.And the tansfer time is slowly.Are there any =
methods that can work like this and more efficiency?
thanks for your response!
Content-Type: text/html;
charset="big5"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Dbig5">
<META content=3D"MSHTML 5.50.4134.100" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DMingLiu size=3D2>Hello all,</FONT></DIV>
<DIV><FONT face=3D=B2=D3=A9=FA=C5=E9>I have PHP ver4.0.6 and =
MapServer version 3.5. and the=20
dbms is <FONT color=3D#ff0000>postgresql7.1.3</FONT>.I want to show the =
big5 on my=20
map.My db had already converted the unicode to the big5,but=20
the map on web still show the unicode.So I want to use =
php/mapscript=20
to convert the word.following is the program that download on=20
web:</FONT></DIV>
<DIV><FONT face=3DMingLiu size=3D2><?php</FONT></DIV>
<DIV><FONT face=3DMingLiu size=3D2> Function=20
U2Utf8($c){<BR> If($c < 0x80)=20
{<BR> =20
$str.=3D$c;<BR> }ElseIf($c < 0x800)=20
{<BR> $str.=3D(0xC0 |=20
$c>>6);<BR> =
$str.=3D(0x80 |=20
$c & 0x3F);<BR> }ElseIf($c < =
0x10000)=20
{<BR> $str.=3D(0xE0 |=20
$c>>12);<BR> =
$str.=3D(0x80 |=20
$c>>6 & =
0x3F);<BR> =20
$str.=3D(0x80 | $c & 0x3F);<BR> =
}ElseIf($c <=20
0x200000) {<BR> =
$str.=3D(0xF0 |=20
$c>>18);<BR> =
$str.=3D(0x80 |=20
$c>>12 & =
0x3F);<BR> =20
$str.=3D(0x80 | $c>>6 &=20
0x3F);<BR> $str.=3D(0x80 =
| $c=20
& 0x3F);<BR> =20
}<BR> Return $str;<BR> =
}</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DMingLiu size=3D2>Function =
Big52Utf8($Big5){<BR> =20
//Modify By MingSen Zhao</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DMingLiu size=3D2> If(!Trim($Big5)) Return=20
$Big5;<BR> $tmp=3DFile("./BIG5.TXT");<BR> =
Foreach($tmp as=20
$key =3D> $value)<BR> =20
$codetable[Hexdec(Substr($value,0,6))]=3DSubstr($value,7,6);</FONT></DIV>=
<DIV> </DIV>
<DIV><FONT face=3DMingLiu size=3D2> =20
While($Big5){<BR> =20
If(Ord(Substr($Big5,0,1))>127){</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DMingLiu=20
size=3D2>$utf8=3DU2Utf8(Hexdec($codetable[Hexdec(Bin2hex(Substr($Big5,0,2=
)))]));<BR> =20
For($i=3D0;$i<Strlen($utf8);$i+=3D3)<BR> =
=20
$ret.=3DChr(Substr($utf8,$i,3));<BR> &=
nbsp; =20
$Big5=3DSubstr($Big5,2,Strlen($Big5));<BR> =
}Else{<BR> =20
$ret.=3DSubstr($Big5,0,1);<BR> &=
nbsp;=20
$Big5=3DSubstr($Big5,1,Strlen($Big5));<BR> =
}<BR> }<BR> Return $ret;<BR>}<BR></FONT></DIV>
<DIV><FONT face=3DMingLiu size=3D2>it need a file "big5.txt" that =
is a u8tob5=20
table.this program can be running correctly.but the word on map is=20
still unreadable.It seems to transfer uncompletely.And the =
tansfer=20
time is slowly.Are there any methods that can work like this =
and more=20
efficiency?</FONT></DIV>
<DIV><FONT face=3DMingLiu size=3D2></FONT> </DIV>
<DIV><FONT face=3DMingLiu size=3D2>thanks for your=20
response!</DIV></FONT></BODY></HTML>
------=_NextPart_000_000F_01C2B6B0.CD274F40--
< ¨C¤Ñ³£ Yahoo!©_¼¯ > www.yahoo.com.tw
