[Mapserver-users] mapserver compile problems
Daniel Morissette
morissette at dmsolutions.ca
Wed Jan 8 14:48:08 EST 2003
Philipp Jacob wrote:
> i recompiled the gdal library.
> configure checked for OGR support and enabled it. well, sounds nice.
> 'make all' 'make install' done..
> then i configured the mapserver again.
> additionally with the option: --with-ogr
> configure finished successfully and i had a look at the Makefile.
> OGR support is mentioned there, and the right paths are set.
> (/usr/local/lib -lgdal.1.1)
> but 'make' brings even more 'undefined references' than before:
> ./libmap.a(mapogr.o): In function `ogrGeomPoints(OGRGeometry *, shapeObj
> mapogr.o(.text+0x16c): undefined reference to
> `OGRPolygon::getExteriorRing(void)'
Looks very much like your libgdal.1.1.so doesn't include OGR support.
Did you do a 'make clean' after you reconfigured your GDAL and before
recompiling and reinstalling it? Did you also do a 'make clean' in the
MapServer directory before recompiling it?
I guess you could also check that OGR is really included in your
libgdal.1.1.so using the following command, you should see about 30
symbols associated with OGRPolygon:
nm /usr/local/lib/libgdal.1.1.so | grep OGRPolygon
The last thing I can think of would be an issue with the order of the
libraries on the link command, but I don't think I've ever seen this
happening on any platform with MapServer.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
