[Mapserver-users] Accessing the cumulative distance value
outside of the status bar
Richard Greenwood
rich at greenwoodmap.com
Sun Jan 12 10:33:38 EST 2003
--=======6225B89=======
Content-Type: text/plain; x-avg-checked=avg-ok-BC9450D; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 8bit
I'm not familiar with Rosa, but I have added distance measuring
functionality to jBox FKA mapplet. It returns the invididual segment
distance and the cumulative distance, which can then be displayed in the
browser's status bar or elsewhere (like in a text box). For a working
example see:
http://www2.tetonwyo.org/mapserver/
and for the java classes and source
http://www.greenwoodmap.com/mapserver/
It will also be available on the UMN site soon.
Having said all that, it seems like you could accomplish what you want with
Rosa and JavaScript. You can read the browser's status line with
s=defaultStatus;
And you could then implement your own running total or whatever.
Rich
At 06:14 PM 1/12/2003 +0800, Steve McCrone wrote:
>After looking at the java source of the 'Rosa2000.java' I see that there is
>not function
>that returns the cumulative distance text that can be called by a javascript
>function.
>So, am I correct in saying that there is not currently a function in the
>rosa applet that allows
>the cumulative distance string to be accessed?
>Not being a java developer would it be possible to Add a function
>in the Rosa2000.java code to return the parameter m_strMsg,
>which i beleive is the string variable that holds the message
>displayed in the status bar. See below:
>protected void readPararam()
> // Get the message.
> m_strMsg = m_applet.getParameter( kstrDistanceMsgParam );
>In the 'Rosa2000.java' have something like -
>public void GetDistMsg()
> return m_strMsg;
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Richard W. Greenwood, PLS
(307) 733-0203
Rich at GreenwoodMap.com
www.GreenwoodMap.com
--=======6225B89=======--
