[Mapserver-users] Working with TrueType Fonts
krung
krung at cad.go.th
Wed Jan 15 10:33:54 PST 2003
Hi Calin,
What platform do you use? On my experience, if Windows, it would show as you want, but Linux not. If Linux, I used full path to font file,eg.
fritqat /your/fonts/path/fritqat.ttf
fritqat-bold /your/fonts/path/fritqtb0.ttf
fritqat-italic /your/fonts/path/fritqti0.ttf
fritqat-bold-italic /your/fonts/path/fritqtb2.ttf
And don't forget to set file and directory permission to your server session.
HTH
Krung
---------- Original Message ----------------------------------
Date: Tue, 14 Jan 2003 17:24:37 +0100
>I am trying to display a True Type font. My map file looks like:
> map
> extent 76952.80 189962.49 92359.36 202061.55
> name "test 2"
> shapepath "data"
> size 600 450
> status on
> fontset 'font/fonts.txt'
> units meters
> LAYER
> NAME roads_name_init
> GROUP "roads"
> DATA "roads"
> MINSCALE 5000
> STATUS ON
> TYPE ANNOTATION
> LABELCACHE ON
> LABELITEM "NUMBER"
> CLASS
> LABEL
> TYPE truetype
> FONT fritqat
> MINFEATURESIZE AUTO
> MINDISTANCE 100
> ANTIALIAS TRUE
> COLOR 0 0 0
> OUTLINECOLOR 220 220 220
> SIZE 11
> ANGLE AUTO
> POSITION AUTO
> OFFSET 0 2
> buffer 2
> END #LABEL
> END #CLASS
>END #LAYER ROADS-NAME
>I created a directory called FONT under the directory where it is the
>'*.map' file
>Here I put all the TTF files and I created a list with the fonts - named
>FONTS.TXT:
> fritqat fritqat.ttf
> fritqat-bold fritqtb0.ttf
> fritqat-italic fritqti0.ttf
> fritqat-bold-italic fritqtb2.ttf
> The error that I get is
> - "MapServer Error in msGetLabelSize(): Could not find/open font
>in <the PHP file>....." - with PHP environment
> - "msGetLabelSize(): TrueType Font error. Could not find/open
>font" - with clasic HTML
>We are using the stabile version of MAPSERVER 3.6.
>Thank you,
>Calin
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
