[Mapserver-users] mapfile mapscale strangeness
Daniel Morissette
morissette at dmsolutions.ca
Thu Jan 16 16:23:12 EST 2003
I would suggest that you check the UNITS setting at the top-level in
your mapfile. It may be set to meters when it should be DD (degrees) or
the reverse. UNITS must represent the units in which your EXTENT is
expressed.
Daniel
Lowell Filak wrote:
> I can't seem to reproduce it here.
> Same version of MS (3.6.3) with older version of RH (7.1).
> Possibly posting the relevant code may help.
> Lowell F.
> The following message was sent by Dana Quinn <dana at nextbus.com> on Wed, 15 Jan 2003 17:48:54 -0800.
> > I'm seeing a strange problem with application of the MINSCALE and
> > MAXSCALE parameters. I'm using 3.6.3, redhat linux 8, and perl
> > mapscript. I'm am working on getting an existing application that
> > works under an old version of the mapserver working on this new
> > version, on a new machine.
> > So this is my new problem - I have layers that are only supposed to
> > turn on at a 'larger scale' - more zoomed in - things like street
> > names and secondary streets and stuff like that, that were turning
> > on when my scale was much smaller. I'd have something like
> > MAXSCALE 40000 in the layer, but when I'd create a map that is
> > zoomed out far enough that I could see complete states, I would
> > still have the MAXSCALE 40000 layers displayed.
> > So after some testing and lots of debug print statements, I
> > found that mapscript, as I compiled it, thinks the SCALE is
> > usually somewhere between 1 and 5. I adjusted some of my MAXSCALE
> > lines to these sorts of values, and things work the way I expect
> > them to.
> > So to summarize - I would expect the scale of the maps I create to
> > be in ranges like 10000-25000, 250000 and so on, but they seem to
> > be smaller numbers like 0.5, 3, so on. Has anyone else seen
> > something like this? Did I blow some configuration option?
> > dana
> > Dana Quinn, dana at nextbus.com
> > NextBus Information Systems
> > (510) 420-3117
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
