[Mapserver-users] Re: Mapserver - Itemquery
Richard Greenwood
rich at greenwoodmap.com
Fri Jan 17 07:08:30 PST 2003
--=======32FE3149=======
Content-Type: multipart/alternative; x-avg-checked=avg-ok-539216BE; boundary="=====================_91392615==.ALT"
--=====================_91392615==.ALT
Content-Type: text/plain; x-avg-checked=avg-ok-539216BE; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 8bit
Steve,
I am not too familiar with the demos so I can't answer your question in the
context of the demos, but what you are trying to do isn't hard. Basically
you need to have just one map file and just one template file for your project.
In your map file, you will need two definitions for the lake layer, one for
normal display of the lake and another for displaying the lake that has
been queried. Give the layer definitions different names e.g. LAKE and
LAKE_QUERIED.
Here's an example (off the top of my head, so it might not be perfect):
QUERYMAP
STATUS ON
STYLE SELECTED
END
LAYER # this layer displays all lakes and allows user to
# click on lake and get lake name
NAME LAKE
TYPE Polygon
DATA "lake"
status default
CLASS
Name "Lakes" # this is just for display in the legend
TEMPLATE "attribute_display.html" # Use to display
attribute data
SYMBOL "Solid"
OUTLINECOLOR 0 0 255
SIZE 2
END # CLASS
END # layer
LAYER # this layer just displays one lake when it has been queried
# for based on lake_id
NAME "LAKE_QUERY"
DATA "lake"
TYPE polygon
STATUS default
FILTERITEM lake_id
Filter "%kake_id%"
CLASS
TEMPLATE tc.html # Use to display map
OUTLINECOLOR 255 255 0
SYMBOL 'solid' SIZE 6
END # CLASS
END # LAYER
In terms of using javascript to set form variables - you should have to for
a basic page. You should be able to get everything you describe working
with standard form controls.
Your template file looks ok, but I think you should add:
<input type="hidden" name="mapext" value="shapes">
I will CC this reply to the list because there is always some out there
with a useful suggestion.
Rich
At 04:37 PM 1/17/2003 +0800, Steve McCrone wrote:
>Hello,
>Sorry for mailing directly, but from previous mails and archives you seem
>quite familiar with CGI mapserver.
>So, if you don't mind me asking you a question -
>Let's start with the demo from the mapserver website. The one that starts
>with demo_init.html,
>demo.map and demo.html, and demo_footer.html & demo_header.html
>Here's what I'm after - I wish to combine the case1 demo in the TestSuite
>with this demo described above.
>In other words, the user selects a lake (from Lakespy2) from a combo box,
>pushes a button and the
>map will zoom into this lake (on the same page - demo.html) NOT opening
>up another page, and highlite it yellow.
>I have the case1 demo working but wish to have it all on the same page.
>I have added a combo box and button -
> Pick one:
> <select name="value" size="1">
> <option> BOWSTRING
> <option> ALICE
> </select>
> <input type="button" value="Go!" onclick="javascript:find()">
>where the user selects a 'lake' and then pushes the button. Then the map
>image zoomed in to this polygon will be loaded
>in the palce of ths img in - <INPUT NAME="img" TYPE="image" SRC="[img]"
>width=600 height=600 border=0>
>Then the user can continue to interact with the map image by zooming
>in/out/panning etc.
>I assume I need to call a javascript function to set the variable etc.,
>which will involve setting such
>variables as -
><input type="hidden" name="mode" value="itemquery">
><input type="hidden" name="qlayer" value="Lakespy2">
><input type="hidden" name="item" value="Lake_name">
><input type="hidden" name="mapext" value="">
>But, I'm at a loss on how to have this function within the same page. I
>also need to set my filters etc in my map page, but when I initially
>load my page the lakespy2 shape file is not loaded.
>I have spent hours searching the archive but have not found anyone who has
>implemented this.
>Thanks for any assistance you can provide. I will continue trying.
>Steve
Richard W. Greenwood, PLS
(307) 733-0203
Rich at GreenwoodMap.com
www.GreenwoodMap.com
Content-Type: text/html; x-avg-checked=avg-ok-539216BE; charset=us-ascii
<html>
<body>
Steve,<br><br>
the context of the demos, but what you are trying to do isn't hard.
Basically you need to have just one map file and just one template file
for your project.<br><br>
for normal display of the lake and another for displaying the lake that
has been queried. Give the layer definitions different names e.g. LAKE
and LAKE_QUERIED.<br><br>
perfect):<br><br>
QUERYMAP<x-tab> </x-tab><br>
<x-tab> </x-tab>STATUS ON
<br>
<x-tab> </x-tab>STYLE
SELECTED<br>
END<br><br>
LAYER<x-tab> </x-tab># this layer displays all lakes and
allows user to <br>
<x-tab> </x-tab><x-tab> </x-tab>#
click on lake and get lake name<br>
<x-tab> </x-tab>NAME
LAKE<br>
<x-tab> </x-tab>TYPE
Polygon<br>
<x-tab> </x-tab>DATA
"lake"<x-tab> </x-tab><br>
<x-tab> </x-tab>status
default<br>
<x-tab> </x-tab>CLASS<br>
<x-tab> </x-tab><x-tab> </x-tab>Name
"Lakes"<x-tab> </x-tab># this is just
for display in the legend<br>
<x-tab> </x-tab><x-tab> </x-tab>TEMPLATE
"attribute_display.html"<x-tab> </x-tab>#
Use to display attribute data<br>
<x-tab> </x-tab><x-tab> </x-tab>SYMBOL
"Solid"<x-tab> </x-tab><x-tab> </x-tab><br>
<x-tab> </x-tab><x-tab> </x-tab>OUTLINECOLOR
0 0 255<br>
<x-tab> </x-tab><x-tab> </x-tab>SIZE
2<br>
<x-tab> </x-tab>END
# CLASS<br>
END # layer <br><br>
LAYER<x-tab> </x-tab># this layer just displays one lake
when it has been queried<br>
for based on lake_id<br>
"LAKE_QUERY"<br>
"lake"<x-tab> </x-tab><x-tab> </x-tab><x-tab> </x-tab><x-tab> </x-tab><br>
polygon<br>
default<br>
<x-tab> </x-tab>FILTERITEM
lake_id<br>
<x-tab> </x-tab>Filter
"%kake_id%"<x-tab> </x-tab><br>
tc.html<x-tab> </x-tab>#
Use to display map<br>
255 255 0<x-tab> </x-tab><br>
'solid' SIZE 6<br>
<x-tab> </x-tab>END #
CLASS<br>
END # LAYER<br><br>
for a basic page. You should be able to get everything you describe
working with standard form controls.<br><br>
Your template file looks ok, but I think you should add:<br>
<x-tab> </x-tab><input
value="shapes"><br><br>
with a useful suggestion.<br><br>
Rich <br><br>
At 04:37 PM 1/17/2003 +0800, Steve McCrone wrote:<br><br>
<blockquote type=cite class=cite cite><font face="arial" size=2>Hello,</font><br>
<br>
<font face="arial" size=2>Sorry for mailing directly, but from previous
mails and archives you seem quite familiar with CGI
mapserver.</font><br>
<font face="arial" size=2>So, if you don't mind me asking you a question
- </font><br>
<br>
<font face="arial" size=2>Let's start with the demo from the mapserver
website. The one that starts with demo_init.html,</font><br>
<font face="arial" size=2>demo.map and demo.html, and demo_footer.html
& demo_header.html</font><br>
<br>
<font face="arial" size=2>Here's what I'm after - I wish to combine the
case1 demo in the TestSuite with this demo described above. </font><br>
<font face="arial" size=2>In other words, the user selects a lake (from
Lakespy2) from a combo box, pushes a button and the</font><br>
<font face="arial" size=2>map will zoom into this lake (on the same
page - demo.html) NOT opening up another page, and highlite it
yellow.</font><br>
<font face="arial" size=2>I have the case1 demo working but wish to have
it all on the same page.</font><br>
<br>
<font face="arial" size=2>I have added a combo box and button - </font>
<br>
<br>
<font face="arial" size=2> Pick one:<br>
<select name="value" size="1"><br>
<option> BOWSTRING<br>
<option> ALICE<br>
</select><br>
<input type="button" value="Go!" onclick="javascript:find()"></font><br>
<br>
<font face="arial" size=2>where the user selects a 'lake' and then pushes the button. Then the map image zoomed in to this polygon will be loaded</font><br>
<font face="arial" size=2>in the palce of ths img in - <INPUT NAME="img" TYPE="image" SRC="[img]" width=600 height=600 border=0></font><br>
<br>
<font face="arial" size=2>Then the user can continue to interact with the map image by zooming in/out/panning etc.</font><br>
<br>
<font face="arial" size=2>I assume I need to call a javascript function to set the variable etc., which will involve setting such </font><br>
<font face="arial" size=2>variables as - </font><br>
<font face="arial" size=2><input type="hidden" name="mode" value="itemquery"><br>
<input type="hidden" name="qlayer" value="Lakespy2"><br>
<input type="hidden" name="item" value="Lake_name"><br>
<input type="hidden" name="mapext" value=""> </font><br>
<br>
<font face="arial" size=2>But, I'm at a loss on how to have this function within the same page. I also need to set my filters etc in my map page, but when I initially</font><br>
<font face="arial" size=2>load my page the lakespy2 shape file is not loaded.</font><br>
<br>
<font face="arial" size=2>I have spent hours searching the archive but have not found anyone who has implemented this.<br>
<br>
Thanks for any assistance you can provide. I will continue trying.<br>
<br>
Steve<br>
</font> <br>
<font face="arial" size=2> <br><br>
</font> <br>
<font face="arial" size=2><</font></blockquote>
<x-sigsep><p></x-sigsep>
Richard W. Greenwood, PLS<br>
(307) 733-0203<br>
Rich at GreenwoodMap.com<br>
<a href="http://www.greenwoodmap.com/" eudora="autourl">www.GreenwoodMap.com</a></body>
</html>
--=====================_91392615==.ALT--
--=======32FE3149=======--
More information about the MapServer-users
